Cupped tires
Old Mar 29, 2021 | 07:26 PM
brooksa44's Avatar
brooksa44
Cupped tires
Hey all,
2000 V10 4X4 242K running 295/16 Cooper AT3 tires, stock springs with helper leaf
dealing with a tire issue lately, after a 650 round trip to beach noticed the tires have gotten really loud, I've always known the fronts cup on the outside but rotation at oil changes kept that in check and never progressed like this.
Now front and rears are cupping on outside and inside, the rears have never been a problem the 21 years of ownership.
This brings me to my question has anyone had similar issue creep up on them? The rears cupping is baffling to me?
I know the usual suspects are alignment, hub bearing, and balancing could be causes?
Anything else I should inspect? I guess shocks? Anything else?
TIA
Thanks to pollen it is easy to see,
Driver front
Driver rear
Pass front
Pass Rear
Old Mar 29, 2021 | 08:54 PM
Big Sky's Avatar
Big Sky
I've had problems with Bridestone Revo 2's and my current set of Hankook Dyna Pro AT2's cupping like that even though I rotate them. In between those I had Michelins with no issues. Not sure if its the air pressure or blocky type tread or not, but it makes it sound like a bearing going out until you elevate it on jack stands and it is quiet.
Old Mar 29, 2021 | 09:01 PM
wpnaes's Avatar
wpnaes
I’ve had that cupping with worn unit bearings and worn ball joints. Neither were worn out, but getting there. Just keep rotating and ignore it IMO (I’m also a 21 yr owner).
Old Mar 29, 2021 | 09:47 PM
SmackDaddy's Avatar
SmackDaddy
This is spot on.
Old Mar 29, 2021 | 09:57 PM
brooksa44's Avatar
brooksa44
yes def going to check hubs again and I guess run it to shop for an alignment check and rebalance and see what that does, have to make another couple of 650 round trippers before it goes for paint in May, trying to hopefully figure it out before the tires are total crap.
Old Mar 29, 2021 | 09:59 PM
brooksa44's Avatar
brooksa44
Originally Posted by SmackDaddy
This is spot on.
Nice! I didn't plan to keep it this long just kind of happened and now I'm too vested to let it go lol.
Old Mar 29, 2021 | 11:10 PM
rockhounds4x4's Avatar
rockhounds4x4
Ball joints?
Old Mar 30, 2021 | 06:24 AM
Dweber85rc's Avatar
Dweber85rc
Check your shocks
Old Mar 30, 2021 | 07:05 AM
brooksa44's Avatar
brooksa44
I did think of the shocks because they have been on the truck for about 10 years if I remember right, as for the ball joints I will check those when I checking the hubs.
Old Mar 30, 2021 | 09:08 AM
Dweber85rc's Avatar
Dweber85rc
If your shocks are 10 years old almost guaranteed they are bad
Old Mar 30, 2021 | 09:31 AM
brooksa44's Avatar
brooksa44
My thoughts too, just pulled the trigger on some Bilsteins,
senix
All Things Towing
79
Oct 9, 2021 08:40 PM
Lex2002
24
Nov 20, 2020 01:07 PM
Greenlawnracing
Jul 21, 2010 11:16 PM
Blueovals&Blacksmoke
24
Jul 16, 2010 09:07 PM
Storm
Oct 6, 2007 08:54 AM
