Does anyone have any real experience with tearing down and rebuilding the power steering boxes from bullnose trucks?
are there any differences that could complicate a Steering Box swap from an 86 to an 80?
Not looking for guesses only hands on knowledge
Why even try to rebuild it?
Well I guess if it is leaking and you are doing a re-seal then maybe but if for play that will not fix it.
Also don't even think of a re-manf. from a parts store as all they do is new seals and send it down the road and could have play or even more than your old one.
I went with a Blue Top as the price was a little less than the Red Head boxes.
They machine where the shafts ride in the housing, this is where the ware is, and install bearings. I am told the factory boxes don't even have bushings, steel on casted housing!
From time ordered to drop at my door was quick and return was easy.
Hardest part was to do a good flushing that BT said had to be done.
...are there any differences that could complicate a Steering Box swap from an 86 to an 80?
I can't help with the repair of a steering box, but I can confirm that steering boxes were the same from 1980 -1996 F150, F250 and Bronco and 1997 F350.
That's called a re-seal. That doesn't fix the inherent flaws of the box. The shaft needs a bushing and that requires machining the case. Go with bluetop or redhead.
You can not properly rebuild the box at home. Reseal it yes rebuild no. It requires some rather specialized tools to rebuild these boxes. To rebuild them properly the recirc ball races need to be ground oversize and oversize ***** installed. There is also the issue of the sector shaft that has no bushings In the Ford boxes the housing it's self act as the wear surface for the sector shaft which is fine for the application but adds another machining step to the rebuilding process.
So you can reseal it at home and add new ***** but unless you have the specialized grinding equipment you can not properly rebuild it.
Be aware most of the NAPA Cardone and similar rebuilt units just reseal and install new recirc ***** and that is it. This takes some of the slop out of an old box but it will not bring back to factory specs in most instances especially if the housing is worn at the sector shaft.
To get a properly rebuilt box you will have to opt for one of the specialized rebuilders remanufacturers. The most notable are Red Top and Blue Top. Given the choice, I'd opt for Blue Top, Red Top has seen some rather extensive growth recently have on occasion been having a few QA/QC issues with their product. .
My power steering system doesn't leak but has slop. I am a machine tool repairman/ machinist with my own machine shop.
I rebuild ball screw nuts as part of my services.
I have a spare steering box to rebuild then swap with my original.
If you rebuild ball screws then you should have no issues remanufacturing the box. Forget the bushing in the housing and opt for a narrow needle, needle bearing to support the sector shaft, Blue Top and Red Head do this with their rebuilt units.
I know you said you already have a box, but if it's going to take a lot of work (really wore out) the best kept secret is to go out and get a box off a Bronco II or a little Ranger pickup. They used the exact same box as the big trucks and led a much easier life. A reseal on one of those boxes may actually work.
The only issue I had was trying to figure out a way to SIZE the Teflon seal rings after I installed them on the spool valve. Looked for a factory tool but could not find one easily. So I took a plastic water bottle with smooth sides, Cut it to just wrap around the spool with just a little overlap. Then used a worm drive hose clamp to snug it up. The plastic would keep the hose clamp from deforming or grooving the Teflon ring. Worked great. You could use a Silicone hose clamp as they have no grooves, but I used what I had with the plastic bottle.
Not sure what you shaft size is, one of the medium duty boxes I rebuilt one time already used the needle bearing on the shaft. It just happened to be the same size as the spindle bearing on my Dana 60. So you might check the spindle bearing sizes against your pitman shaft. But you being a machinist you can find the ones you need.
