speedometer is acting up
Old Mar 26, 2021 | 06:34 PM
f-1minty's Avatar
f-1minty
speedometer wont work if i go slower then 20 mph now. for awhile it didnt work at all while i was searching for the problem. i was reading that the speedometer reads off of the abs sensor or something for my truck. if it does then that might explain the abs light. is there a common thing that fails at roughly 139k miles or do i just have a bad part somewhere?.
thanks, lane
Old Mar 27, 2021 | 06:48 AM
tjc transport's Avatar
tjc transport
i ain't rite
what are you working on?
could be a bad speedometer, or a bad speed sensor or a bad PSOM on cluster if 92 and newer, or a bad cable if 91 and older,
Old Mar 27, 2021 | 03:06 PM
f-1minty's Avatar
f-1minty
im not to good with the sensors but the odometer doesnt work if that helps narrow it down. truck is a 94 5speed if that also helps
Old Mar 27, 2021 | 04:08 PM
tjc transport
i ain't rite
94 has a vehicle speed sensor in the rear axle. it also has what is called a PSOM on the back of the cluster that controls the speedometer..
but with you saying the ABS light is also on, i would be suspecting the VSS, because the RABS reads off that too.
Old Mar 27, 2021 | 09:55 PM
f-1minty's Avatar
f-1minty
thanks, ill look into getting a new one.
Rockhauler98
Large Truck
Oct 14, 2020 11:49 AM
tperk100
Oct 28, 2017 02:42 AM
cabloom300
Jun 26, 2012 04:18 PM
SteveO.
Aug 26, 2008 10:05 AM
99strokun
Sep 25, 2007 09:43 PM
