Radiator mounting issues
Old Mar 24, 2021 | 07:57 PM
OK F1's Avatar
OK F1
I was hoping someone here has run into this problem before and come up with a solution. I have a walker radiator with the attached AC condenser. When I went to fit the radiator into the radiator support the cross brace on the support interfered with the AC condenser. I feel like my only option is to grind off the rivets holding the cross brace, And install spacers to move the cross brace out far enough to avoid the AC condenser.
I looked at unscrewing the condenser from the radiator and putting it lower so it was under the cross brace, but there just isn’t enough room. If this seems way off base, please let me know. I feel like this is the best option but I would love to hear opinions.
About 1” needed for clearance.
Old Mar 24, 2021 | 08:13 PM
52 Merc's Avatar
52 Merc
Actually, I think that sounds like the most functional and feasible option, not to mention the easiest way to address the issue. Go for it.
Old Mar 25, 2021 | 10:45 AM
schoo's Avatar
schoo
I used a condenser from old air in Texas 12”x I think 22” it bolted under that cross brace works great for me
Old Mar 25, 2021 | 11:04 AM
schoo's Avatar
schoo
This is before I mounted a 7” spal pusher fan on the right side
i believe that the cross bracket holds the horseshoe from spreading with the weight of the fenders
Old Mar 26, 2021 | 03:40 PM
AZAV8's Avatar
AZAV8
To get the condenser to fit on the front of the radiator with the radiator mounted to the support frame you will have to remove the cross brace and install spacers. That is what I did to mine. I removed the rivets, made spacers out of 3/4 inch square bar stock and bolted it back together using the original holes in the cross brace. I made up a threaded nut plate for the button head Allen bolts so I would only have to hold one nut in place while I bolted it up. Here are a couple of pictures of the completed installation.
Condenser mounted to the radiator in the radiator support with the reinstalled cross brace.
Cross brace, spacers, nut plate and bolts.
Front detail of the bolted cross brace.
Detail view of the cross brace, spacer and nut plate installed.
My radiator is from U. S. Radiators, and the condenser is a Vintage Air unit. I attached the condenser to the aluminum frame of the radiator with #6-32 screws in holes I drilled and threaded in the radiator side frame.
Let me know if you have any questions.
Old Mar 26, 2021 | 05:00 PM
OK F1's Avatar
OK F1
Exactly what I was looking for.
I got Wayne's approval and pulled the trigger almost immediately. I didn't execute it as well as you did though. I used barrel spacers and hex bolts as a proof of concept, but wasn't very happy with the result (partly because the spacers were too long and it was hard to tighten the nuts onto the bots inside the support). I dont have any pics of my result, but it's probably for the best I don't.
Now that I've seen yours Phillip, I am going to copy that design exactly! Thank you so much for your input! I knew someone here was probably smarter than I am, and you proved me right! Reps coming your way!
BTW, my condenser came preinstalled to the radiator, but I will use the method you used to attach the fan and shroud to the radiator.
Old Mar 26, 2021 | 06:16 PM
AZAV8's Avatar
AZAV8
I center punched the rivets and then drilled through the head down to the brace surface. Then I used a cold chisel to whack off the head and a punch to remove the rest of the rivet. Once the brace is off, bolt your radiator/condenser to the frame and lay the brace across the condenser. You can then measure how much of a spacer you need and add in at least 1/8 inch more. It was easy to make up the nut plate and it is easier to hold in place while you start the bolts. I used stainless steel bolts and a thread lube with the nut plates.
Old Mar 26, 2021 | 07:02 PM
OK F1's Avatar
OK F1
NOT the way to do it, but we’ll call it plan B if I can’t achieve the results AZAV8 (Phillip) did.
Old Mar 27, 2021 | 07:07 AM
49willard's Avatar
49willard
I did the same. In my case 3/8 spacers did it for me.
DDB1973
Apr 19, 2020 04:04 AM
Adam Jones
Feb 22, 2016 10:03 AM
67duster
Oct 16, 2013 11:54 AM
mrblonde108
Dec 28, 2011 11:20 PM
marvinlong
Nov 22, 2004 08:06 PM
