Leaking coolant problem solving help
Old Mar 23, 2021 | 10:58 PM
Greg-93’460's Avatar
Greg-93’460
1993 f250 w/ 460 148,xxx miles
So I’ve had various issues with leaking coolant over the last few months. Did a pressure test and found the oil cooler L hose was dripping a little bit in addition to both sides of the radiator. Classic eh?
Removed the oil cooler and converted to remote filter. Replace radiator. Replaced upper radiator hose idled it till it got up to temp and nothing leaked.
wife’s car didn’t start the next day at 5am so she took the truck 10 miles across town. When she got back it was steamin, reservoir was totally empty 😲🤬.
went back to pressure testing and it’s all dry around the block. But started drippin real good from right below the belt tensioner. Can’t see exactly up there though.
she said the temp needled isn’t get out of the normal zone, but that’s cuz there was no fluid in there I assume.
what I’m wondering is, how much do-do 😡😫 am I in with it not having coolant in it? Assuming the water pump needs to be replaced cuz it cracked. But I would rather not get in there and learn the block it cracked beneath it.
debating just sellin the darn thing.
Old Mar 24, 2021 | 04:00 PM
jas88's Avatar
jas88
Dude there is no way to know, you will just have to fix the leak (water pump?), fill it up with coolant, and see how it goes.
Old Mar 24, 2021 | 04:15 PM
muhford's Avatar
muhford
Just pull the water pump off and take a look at it. Might be as simple as that.
Old Mar 24, 2021 | 07:09 PM
spurredon's Avatar
spurredon
The 460 is a big engine, it can take the temp. better than say a 302. I agree, swap out the pump and any of the other hoses that are near end of life!
Old Mar 26, 2021 | 12:11 PM
Greg-93’460
that makes my heart smile. Haha
it wasn’t to far or long or hauling anything just didn’t know.
lookin to order parts. Any idea what gasket(s) I’ll need? Looks like a plate to block or pump to plate 🤷🏻‍♂️
also I’m planning to replace fan clutch at the same time. Anything else in there I should swap out? Timing chain or anything?
I’m about a year into this fixing things, buying tools adventure so I’ve stil got tons to learn. Adjusting timing would be to much for me at this point. So I would rather avoid the chain but I know if it goes, the whole trucks gone.
Old Mar 26, 2021 | 02:35 PM
muhford's Avatar
muhford
The water pump is belt driven. Change the belt and tensioner. Check the idler too. Keep the old belt as a spare.
You'll want both gaskets. Pump to plate and plate to block. Buy some RTV to seal up the gaskets. The gaskets are huge and can be tricky to line up. Use some dowels or studs in the holes on the engine to line it all up. Youtube is your friend. Pulling the radiator will give you some more room to work.
fordtruckrodder
Aug 12, 2020 03:54 PM
Markus Luukko
Jul 8, 2019 12:41 PM
Byrd.Dog
Jul 16, 2018 10:02 AM
ElMoco
46
Nov 28, 2016 09:42 PM
fordtruckrodder
Oct 11, 2016 11:45 AM
