Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
gen 1 Lightning help
Old Apr 15, 2021 | 04:38 PM
offshore's Avatar
offshore
Trailering
Hey guys quick question concerning the first gen lightnings. I am starting the process of rounding up parts to go through basically the entire chassis. Brakes, lines, bushings, shocks, the works. I know that there a lot of unique items to the Lightnings what about things like disks/calipers, rear drums? although as cheap as the kit is i may just do rear disk conversion. Where can i get Lightning specific front end rebuild stuff like sway bar links/suspension bushings and shocks? Is there a list anywhere that lists that SVO did as far as upgrades from standard F150 stuff? thanks all . ..
Old Apr 15, 2021 | 07:10 PM
Blurry94's Avatar
Blurry94
The front brakes, anti sway bars, heads, intakes, cam, transmission (tuning), dirveshaft, rear end housing, LS differential & 4.10 gears.
You can probably find some parts on LMC Truck or Late Model Restoration.
Old Apr 15, 2021 | 07:41 PM
2dwoods's Avatar
2dwoods
Probably need a disc brake conversion for 8.8 diff,and there might even be a junk yard conversion from newer 8.8. I got all my stuff for front from Napa it was all moog but I'm not pushing moog
Dont buy those white pivot and radius arm bushing they just break into pieces ,get rubber oem or red poly
Its easy to get wrong stuff I've had lightning long time so hears another tip measure your shocks buy them by what length you need because they say lightning but it comes for f150 without the lightning drop
Old Apr 17, 2021 | 10:15 PM
offshore's Avatar
offshore
Trailering
cool, thanks guys. i kinda thought the front brakes might be different/bigger. Seems like a rear disk conversion is a good (and very reasonably priced) way to go for the rears. Also very much considering lowering and leveling it if i can find a proper kit for it. I've seen drop beam kits but most places appear to be out of stock.
this is actually the first i have ever really even been around a Lightning. Always wanted one but very few and far between, really diggin this thing.
would a standard F150 lowering kit be the same for a Lightning?
Old Apr 18, 2021 | 05:46 AM
2dwoods's Avatar
2dwoods
They come dropped about 1 and 1/2 from factory I just saw a guy on tube that used the drop beams but with lightning coils it was to low so he had to put regular f150 coils in and there's 3 types reg./ heavy/ heavy duty. He had to go with the reg.to get right height
Old Apr 18, 2021 | 07:47 PM
offshore's Avatar
offshore
Trailering
thats funny, i literally just ran across that today on youtube. They were doing a build off with an ss 454 as well then did a showdown (i havnt got that far yet so no spoiler lol)
im going to have to give the drop spindles some more thought. Actually id be happy if it was just level. Dont really want to swap the springs to stockers assuming the Lightnings are a performance spring of some sort.
Old Oct 9, 2021 | 05:36 AM
chesster51's Avatar
chesster51
What's the latest on this? Inquiring minds want to know.
Old Mar 4, 2023 | 06:41 PM
Baykar's Avatar
Baykar
Trailering
Did spiderman install your bedliner? Lol
Old May 10, 2024 | 10:08 AM
EQCMCAT's Avatar
EQCMCAT
Offshore,
Question. In an earlier post of yours above (2021) you mentioned you drained the old fuel, am curious how you accomplished it?
I'm going to have to drain fuel in my stored 1993 F-150 Supercab at some point in the future, so I'm curious.
Old May 17, 2024 | 11:22 AM
Papa Tiger's Avatar
Papa Tiger
Post died 3 years ago. Haha
Johnny Mayday
2015 - 2020 F150
Aug 1, 2019 08:37 AM
95centurion
Apr 8, 2016 03:39 PM
skidmarks82
1997 - 2003 F150
Mar 7, 2015 05:12 PM
frdboy
Jun 14, 2004 08:35 PM
