Help Decoding a F600
E = 361 2V FT gas V8
C = Ontario Truck Plant
N81595 = 1972 series number
194 = 194" wheelbase
B = Light Blue
F605 = F600 gas 4x2 19,200lbs GVWR
238 = I don't have seat or upholstry info, and there seems to be a gap in what I do have. Best guess is standard cab.
M = Clark model 285V five speed direct transmission
F3D
F3 = Eaton model 15201 2 speed rear axle, ratios 6.33/8.81, 15,000 lbs. capacity (From a prior decode by Numberdummy)
D = Ford Rockwell (Timken) front axle, 7,000lbs capacity
19200 19,200lbs GVWR
182 3800 = 182 certified net HP @ 3800 RPM
25 = Richmond District Code
I
Let me know if something doesn't line up and I'll double check
