vin decode 1970
vin decode 1970
Hi I needed some help decoding my vin on a 1970 f600. I got some help from others hear but was interested in the rear end size and gear ratios. The 1970 rear end looks alot bigger than a 1968 one that I have. Both are 2 speed rockwells. I'm trying to build one truck out of two and deciding what parts are best. Had another thread a few weeks back just starting a fresh one thats maybe less confusing.
Thank you
F61DRJ83226
194 M F612 48 2 E3C
23000 164 3800 71
Thank you
F61DRJ83226
194 M F612 48 2 E3C
23000 164 3800 71
We already did part of this one. But I digress:
F61 = F600 gas, 4x2
D = 330 2v HD FT engine
R = San Jose assembly plant
J83226 = 1971 serial sequence
194 = 194 inch wheelbase
M = White
F612 = F600 gas 4x2 23,000lbs GVWR
48 = Standard cab w/o back of cab equipment (double check this, could it be "4B"?)
2 = Clark 282V 5 speed direct transmission
E3 = Eaton model 16244 2 Speed Rear Axle / 6.50/9.04-1 / 17,500 lb. Rear Axle Capacity
C = Ford 6,000lb capacity front axle
23000 = 23,000 GVWR
164 3800 = 164 net HP @ 3800 RPM
71 = Los Angeles district code
EDIT: I found that axle code in the decoded info of another 1970. Given the weight rating of it and the front vs. the 23,000 GVWR, it looks right.
F61 = F600 gas, 4x2
M = White
23000 = 23,000 GVWR
F61 = F600 gas, 4x2
M = White
48: 4 = Charcoal Black Kiwi Vinyl & Charcoal Black Diamond Basketweave Vinyl // 8 = 81A Standard Cab.
23000 = 23,000 GVWR
F61 = F600 gas, 4x2
M = White
23000 = 23,000 GVWR
