Please Help - Courtesy Light Module
Old Sep 17, 2020 | 03:21 AM
turbogus's Avatar
turbogus
Hello everyone,
Can someone please tell me where the Module is for the Courtesy Lights and if the Module is available anywhere? I'm having difficulty locally.
Thanks and a lift of the lynch lid for any responses.
Gus
Old Sep 17, 2020 | 04:04 AM
JWA's Avatar
JWA
We're not mind readers here--WHAT are you working on exactly?
Old Sep 17, 2020 | 04:34 PM
turbogus's Avatar
turbogus
Sorry JWA, I have a prior thread that received several visits but no responses so I'm attempting to reframe my question. Shortly after getting this 1998 E 150 the Courtesy Lights have not always shut off, thus draining the battery. With increasing frequency I've been forced to angle the individual lights slightly to break their connection.
I've gone to the TSM for my van and step one is to disconnect the Light Switch, which I've done with no results (the lights stay on). The next step is to disconnect the Courtesy Lights Module, but the TSM is lacking when telling where that Module is.
So I'm hoping that someone has a pic or can direct me. Also in case the module is faulty, I looked online yesterday for a replacement, to no avail. I was hoping that someone my know of a source that I overlooked.
Old Sep 17, 2020 | 05:08 PM
Conanski's Avatar
Conanski
I'm not so sure a 98 would have a separate module for that, but it might have a relay that could be stuck, or it could be one of the door switches that is the problem.
Old Sep 17, 2020 | 10:52 PM
turbogus's Avatar
turbogus
Thanks Conanski, I was taking it step by step by the TSM but a tangent at this point may be a good idea. Thanks! Actually I'm thinking it may be another overtaxed circuit light the multifunction switch was on mine, I had to run a bypass to a floor dimmer switch in the end.
Edit: I just had an idea, it may be the back interior cargo light rocker switch is in the wrong position. I'll have a look tomorrow.
Old Sep 19, 2020 | 01:05 AM
turbogus's Avatar
turbogus
Hmmm, I checked out the rear cargo light (whatever it's called) and the treble switch was to the right. I centered it and after a pause, the Courtesy Lights went out. I guess I can put this down to operator error, that is if my battery isn't drained in the morning.
Edit: Yep that was it, for the last several months. Now if I can ever get the Keyless Entry working again I'll be in fine shape!
DAFBFD58
May 2, 2020 06:27 PM
Dale Massey
Aftermarket Products
Jan 31, 2019 10:14 PM
04F-250mark
Mar 7, 2012 11:32 AM
Propr801
Dec 2, 2009 09:07 PM
