Oil leak. -looks like it is coming from between the reservoir and the block or front cover? Is there a gasket that goes between the two? All these years and I have not had to go down this rabbit hole.
Sorry to hear Buddy,
Start with putting in a new hpop gasket.
If it still leaks,,, try to look underneath the hpop with a camera or morror,,, kinda tough but with the right angle you will be able to see it where it's coming from. If the cover has never been off,,, most likely the culprit.
First pic is description of oring and silicone areas,,, your most likely leak is from the center silicone area.
I think this is what sets under the res. I can not find a simple how to so I guess I will just dive in. I do not think it is a front cover leak I know someone has had to do this . .
The res. sits above the hpop. If it was the res. it would leak on top of hpop not below it. If your leak is under the hpop,,, it's likely hpop gasket or front cover.
Originally Posted by BuddyBarnes
HPOP Reservoir Gasket 94-95
Part Number:F4TZ6619A
