Building boost when not on throttle
Old Mar 18, 2021 | 06:01 PM
James Heller's Avatar
James Heller
So I have a 15 F350 PSD and I can't figure out why my truck builds boost (between 3-7 psi) when not on throttle. It doesn't happen all the time. But usually after passive regeneration. Is the DPF clogged? Is there a boost leak? Is it oil in the intercooler issue? I'm lost thanks in advance.
Old Mar 21, 2021 | 09:58 AM
speakerfritz's Avatar
speakerfritz
I would go with the last one.
came back from a 3 hr trip last week and was having the same problem....idle and boost crawl. pulled a few of the intercooler pipes and found oil every where.
my dealer just did an oil change and had to get every last possilbe drop into the oil fill. I like to keep my oil on the low side so that its harder to get sucked in thru the CCV which is supposed to have an oil catch..but like the water sepereator....the oil catch in the CCV does not work either.
Jay David
2009 - 2014 F150
Feb 17, 2018 10:46 PM
RmMillertime
6.4L Power Stroke Diesel
Feb 22, 2016 03:32 PM
ssmokey24
Jul 15, 2015 07:42 AM
wannabe7.3
Feb 25, 2015 02:15 PM
dtruzinski
May 30, 2004 12:04 PM
