10k mod
Old Oct 27, 2003 | 06:04 PM
F0rdF0rever's Avatar
F0rdF0rever
10k mod
I want to do the 10k mod on my 95 psd. But I was wondering if there were any problems or side effects that could result. Also would someone who has done this 10k mod please give me instructions.
Thanks
Old Oct 27, 2003 | 07:17 PM
Boss300's Avatar
Boss300
I did it and I havent messed anything up, soem other guys do it with a chip and other mods. it will wake up the motor a lot. on the drivers side cylinder head next the the fuel filter there is a sensor with 3 wires, unplug the sensor and look straight at the connector, there will be two holes on the top and one on the bottom, splice into the wire that comes out of the top right connector and the middle one while looking straight on at it and connect them together with a 10k resistor and plug the connector back in. I ran wires to a switch under my dash so i can turn it on and off due to it making the idle rough.
Old Oct 27, 2003 | 08:29 PM
jharvey3's Avatar
jharvey3
Forgive me, I'm a newbie to PSD's but what does this mod do for you? And does the engine need to have a certain number of miles on it before doing mods?
Thanks
John
Old Oct 28, 2003 | 05:02 PM
Boss300's Avatar
Boss300
Basically what it does is tell the computer that there is less injection pressure than there really is so the computer increases perssure which gives it more fuel.
Old Oct 28, 2003 | 06:05 PM
F0rdF0rever
Well, I just finished my 10 k mod. All I can say is wow. If you havent done this mod already, go out andf do it now. Ten minutes and 99 cents later you will have an awesome result. My only question is why dont they come like this from the factory?
Old Oct 28, 2003 | 08:01 PM
ltfox's Avatar
ltfox
I havent heard much about this.? Can you do it to the 94-97 PSD???
Old Oct 28, 2003 | 09:08 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Yes.
Old Oct 29, 2003 | 11:09 AM
jharvey3's Avatar
jharvey3
Please don't think I'm being stupid but how did you splice into the wires? Got a pic you could post?
Thanks
John
Old Oct 29, 2003 | 04:08 PM
F0rdF0rever
There is a plug to the right of your fuel filter, on top of the block. Unplug it. There are three wires, one is brown you will leave this one lone. Very carefully with a pair of of wire strippers peel back about a half inch of the insulation on the other two wires. Then splice a 10k ohm resistor onto the exposed wires, and tape them up with electrical tape. Plug back in and let start er up.
Old Oct 29, 2003 | 04:39 PM
International Tech's Avatar
International Tech
just asking, how many miles do ya'll w/ this mod have? Having any injector problems?
Old Oct 29, 2003 | 08:02 PM
jharvey3's Avatar
jharvey3
FOrdForever
Thanks, that's what I thought just wanted to make sure think I'll do this mod tomorrow.
John
Old Oct 29, 2003 | 10:08 PM
Ggg6's Avatar
Ggg6
I have at least 30k with the 10k and no problems. It really helps the low end and turbo lag. I have no bad idle symptoms. Use a 1/4 or 1/2 watt resistor. You can even play around with different Ohm values. The lower the Ohms the more the effect.
Old Oct 30, 2003 | 09:23 AM
Tha50Kid's Avatar
Tha50Kid
How has this mod affected fuel milage. Did you lose/gain fuel milage with this mod. I would think more injector pressure would result in a little less fuel milage, but feel free to correct me.
Old Oct 30, 2003 | 12:15 PM
99f250's Avatar
99f250
Ggg6--
how is it that you have no idle problems? i did this mod and my wife told me it was too hard to drive it the way it was.
Old Oct 30, 2003 | 05:03 PM
F0rdF0rever
I havent had any idle problems either, just got a bit louder.
