Steering box???
Old Mar 16, 2021 | 09:34 AM
20excursion's Avatar
20excursion
Steering box???
I’m sure this has been asked but what is everyone’s opinion on oem vs a blue top steering box. Thank you in advance
Old Mar 16, 2021 | 08:49 PM
Lance Helmert's Avatar
Lance Helmert
I would buy a new box from BBB or Lares.
Old Mar 17, 2021 | 11:38 AM
CousinCarl's Avatar
CousinCarl
Blue top here. Excellent product.
Old Mar 17, 2021 | 01:03 PM
Ogre20012001's Avatar
Ogre20012001
I put a redhead on mine just because it was less than the blue top.
I have been very pleased with the redhead.
Old Mar 17, 2021 | 01:11 PM
ford390gashog's Avatar
ford390gashog
BlueTop or Redhead for a rebuilt box.
Old Mar 18, 2021 | 09:07 AM
pirate4x4_camo's Avatar
pirate4x4_camo
RED AND BLUE tops are OEM boxes that are remanufactured. nobody, not even Motorcraft has a new OEM steer gear available.
the botique rebuilders like red and blue exisist because they can rebuilt fewer boxes to a higher tolerance and offer custom options that motorcraft can not.
the big draw back is the red and blue guys can not get new sector shafts and have to reuse the most failure prone part of the box.
so the choice becomes, motorcraft rebuilt box with lower tolerances but new sector shaft
or a red or blue remanufactured with your desired options to a tighter tolerance but a used sector shaft.
if you want the best, buy a remanufactured Motorcraft box and have it sent to red company to get a #3 torsion spring.
Old Mar 18, 2021 | 09:59 AM
20excursion
Pirate4x4_camo
If send that reman box to red company do they just put the spring in or do they go thru it again and put the spring in??
Old Mar 18, 2021 | 10:05 AM
ford390gashog
Since when do the Motorcraft rebuilds automatically include a new sector shaft? That has not been my experience with them. The redhead and Bluetop boxes are also machined for a lower bearing. I would check with both rebuilders on the sector shaft availability as last I knew there were new ones available from Crown.
Old Mar 18, 2021 | 10:36 PM
pirate4x4_camo
more like do they still install new sector shafts ? very likely the supply dried up when Visteon shuttered the steering plant in 2008-9 ish
for sure the rebuilds were using new sectors up until this time frame, I can not say 100% if they are now.
Old Mar 19, 2021 | 05:39 PM
SmackDaddy's Avatar
SmackDaddy
I have no complaints about my Blue Top. The whole experience and performance has been great.
Old Mar 20, 2021 | 08:28 AM
20excursion
How long have you had your blue top??
Old Mar 20, 2021 | 08:41 AM
GrndHrdStyHmbl's Avatar
GrndHrdStyHmbl
Quick Queston on the Steering Boxes.....
I have an 04 6L.....4X
My steering wheel kind of does a no effort 1" sag to driver side.......
and when i am holding the wheel dead center it's got like 3" of play in it in terms of like Left to Right.......for example if i was going to "Turn Right" there is 1" or so of steering wheel turn with no wheel movement......
Additionaly, about 2 of the 3" of "play" is when i turn left and then only an 1" when i turn right......
any insight? would a steering box possibly help with this issues?
Thanks!
Old Mar 20, 2021 | 09:02 AM
wpnaes's Avatar
wpnaes
Thanks!
Assuming you’ve looked the many posts in the tech folder under ‘steering’?
https://www.ford-trucks.com/forums/5...-steering.html
The steering box on mine benefitted from an adjustment. Assuming you have your original steering box?
Old Mar 20, 2021 | 09:15 AM
SmackDaddy's Avatar
SmackDaddy
I believe around 30,000 miles
F250racer
Montana Chapter
Apr 30, 2014 08:17 AM
