Code po118
Old Mar 15, 2021 | 03:55 PM
fixorepairdaily's Avatar
fixorepairdaily
Code po118
96 f150 4.9l 5 speed. Someone disconnected the coolant temp sensor on the thermostat housing and replaced with wjth a mechanical gauge so now the ecu has no input from it. It runs poorly when it gets to operating temp and gets terrible gas mileage. How do i buy a new one and wire it in? They removed the wiring to it.
Old Mar 15, 2021 | 04:18 PM
fixorepairdaily
Im assuming this is the connector for it? It seems to run directly to the ecu
Old Mar 16, 2021 | 06:26 PM
Scndsin's Avatar
Scndsin
Don't know on a 4.9 exactly where the ECT sensor is, but that looks like where your under hood courtesy light would plug in.
Old Mar 20, 2021 | 06:15 PM
fixorepairdaily
Thanks good to know, i geuss someone removed it or it wasnt ordered with one? But i found the wiring for the ect it was hidden under the intake
Old Mar 21, 2021 | 12:50 AM
King_Kong's Avatar
King_Kong
When that coolant sensor isnt hooked up, the computer tells the injectors to run rich so the engine will get warmer quicker...in other words, after you fix the sensor issue, you will probably need to blow out some carbon by running a can of seafoam in the gas tank & hammering the throttle several times on the highway.
Old Mar 21, 2021 | 05:09 AM
torq'ta 5 8's Avatar
torq'ta 5 8
O'reilly's has sensor and connector, so does rock auto
Old Mar 24, 2021 | 06:24 PM
fixorepairdaily
Yea it ruined the o2 sensors! It runs too rich and it has a code saying its too lean on both sensors, long term fuel trim is like +20 on both banks im suprised it even runs decent but it does get atrocious gas mileage, ill be changing the sensors when they arrive in the mail
Old Mar 24, 2021 | 11:18 PM
fixorepairdaily
i changed it last week, but because i drove so long without it ill have too change the o2 sensors as well
dlivermore66
1997 - 2003 F150
Sep 18, 2013 06:38 PM
Super crew hunter
1997 - 2003 F150
Apr 11, 2013 06:41 AM
texastech_diesel
17
Feb 4, 2010 07:26 PM
akoz
May 23, 2009 03:01 PM
John_E
Feb 18, 2004 07:53 AM
