1995 F-150 4.9L check engine - ECT code
Here's what I've done:
replaced t-stat (twice) - 192 degree
flush/replaced coolant and purge air
replaced engine coolant temp sensor
replaced blower motor resistor - was gone, only had high speed...
...thought this was my problem
got great heat and AC now...
The catch is that the gauge barely touches the 'N' (Normal), but I
do see it go down lower and then climb back up as if the t-stat is
working. But, that doesn't make sense since it's a 192 degree t-stat
so I'd expect a higher reading on the gauge and not get the ECT code.
I didn't believe the facory gauge, so I added an aftermarket gauge
(mechanical bulb type) with a brass 'T' where the sensor is and it
didn't move (130 degree min), BUT it did move up when I shut the
truck off...maybe hit 170 max. As soon as I start the truck up, it
comes right down at idle (seems to be due to the coolant circulating)
and stays at the min setting. As it drops down, on cue, the check
engine light comes on.
I did another test where I took the heater hose and made a bypass
of the heater core and didn't see any difference. Then, I crimped that
bypass hose so no coolant would flow and sure enough, I saw the temp
come up a little higher and it was just enough to NOT get the check
engine.
Pardon my french, but what the 'F'?
between 2 and 3 digit codes... oops.
This is looking more like a combo of EGR and O2. There is also a code
about the CPP (clutch pedal position). I still don't believe that the engine
is at the proper temp, but until I get the correct code for that, then I'm
going with what I have.
I don't know how your 95 is set up, but my 90 has two temp sensors. The one right by the thermostat has two wires and is used by the ECM to adjust fuel mix. The other sensor has one wire, and is used by the dash temp gauge. This sensor is located under the manifold, on the passenger side, and close to number 4 cylinder.
You can always use a candy thermometer in the radiator with the cap off to get an idea of what the water temp actually is. I would expect 10- 20 degrees lower than the thermostat temp.
Hope this helps.
Good Luck Frank
I did see the part on the clutch pedal being down for the KOEO test (that's the one, right), so I wrote off the CPP codes as TBD. I just ordered the EGR valve ($78 ouch!), and will get that in and recheck codes.
Just for sanity sake, these are my codes:
KOER - 172, 332, 528
KOEO - 522, 332
The only strange thing was the '172' (O2, lean). Again, I'm writing that off to getting
the EGR replaced first.
Thanks again!
Good luck and don't take the old EGR off until you've ruled out everything else in that system! You can verify it by using a piece of tubing to suck the air out of it while the truck is idling. If it stumbles and almost dies then the EGR itself is probably good.
What's with the coffee can? I see the one up front near the battery. but I thought that had something to do with the excess fuel return. Are you saying that is a vacuum resevoir or there's another coffee can somewhere else?
The truck's got a ton of miles (over 180,000) and it doesn't look like anyone has touched that motor or much in the engine bay. Thanks.
