Sponsored by: Real Truck
Continuous NOx sensor issues
Old Mar 15, 2021 | 09:58 AM
Jmsal88's Avatar
Jmsal88
2016 F250 having a reoccurring issues with the NOx sensor. Been to the dealership 4 times for the same issue each time they say the NOx sensor seems to be workin properly and the levels are fine, but they end up replacing the sensor just to get it back on the road. It’s good for few weeks or few months and then happens again.Truck is still under factory warranty only 55k miles. Anyone ever seen this before? Does it sound like a pcm issue? Or would full delete fix the issue?
Old Mar 15, 2021 | 10:46 AM
redford's Avatar
redford
FTE Leadership Emeritus
What issues are you having? Why does the service department think the NOx sensor is to blame?
Old Mar 15, 2021 | 11:23 AM
Jmsal88's Avatar
Jmsal88
the code is for the NOx sensor or so they say. Exhaust fluid system fault light comes on 50 miles to limp mode
Old Mar 15, 2021 | 01:21 PM
redford's Avatar
redford
So you don't know the actual error code?
Isn't that supposed to happen when you run low on DEF?
Flynman
Jul 28, 2020 08:49 PM
W7PSK
6.7L Power Stroke Diesel
Jan 28, 2016 11:41 AM
JOHN2001
Aug 9, 2012 09:21 PM
Rubicante
Apr 20, 2000 08:52 PM
