2016 F250 having a reoccurring issues with the NOx sensor. Been to the dealership 4 times for the same issue each time they say the NOx sensor seems to be workin properly and the levels are fine, but they end up replacing the sensor just to get it back on the road. It’s good for few weeks or few months and then happens again.Truck is still under factory warranty only 55k miles. Anyone ever seen this before? Does it sound like a pcm issue? Or would full delete fix the issue?
What issues are you having? Why does the service department think the NOx sensor is to blame?
