Brake Pedal not returning
Old Mar 14, 2021 | 10:04 AM
F100wish's Avatar
F100wish
I am having a problem with my brake pedal not returning the last inch or so. I have a frame mounted CPP brake booster and front disc/rear drum with backflow valves. I have a Ron Francis brake light switch on my brake arm and this is causing the lights to stay on. Has anyone had this problem before and has anyone used a return spring to bring the brake arm all the way back?
Old Mar 14, 2021 | 02:31 PM
Indybeer's Avatar
Indybeer
Can you physically pull the brake pedal back the rest of the way so the light goes out and the arm hits the bump stop?
Old Mar 14, 2021 | 02:42 PM
F100wish's Avatar
F100wish
Yes I can by lifting on the brake pedal. Only did this after we started truck, prior to starting pedal came back by itself.
Old Mar 14, 2021 | 03:08 PM
Indybeer's Avatar
Indybeer
Are the brakes actually applied, or just the brake light staying on? Could just be an adjustment issue with the rod between the booster and brake arm or brake switch itself.
I have same kit, except for brake light switch
New parking brake cable installed
Old Mar 14, 2021 | 04:36 PM
Scottydog1001's Avatar
Scottydog1001
Mine needed a return spring.
Old Mar 15, 2021 | 01:50 PM
tonyguns's Avatar
tonyguns
I'd love to see a picture of how you solved for this, my pedal is a little slow on the return travel, and I have been pondering some sort of return spring setup.
Old Mar 15, 2021 | 01:59 PM
F100wish's Avatar
F100wish
Yes Scottydog could you post a photo please?
Old Mar 15, 2021 | 02:21 PM
52 Merc's Avatar
52 Merc
Assuming you're working on a 53-56, you didn't say, the parts book calls for a brake pedal retracting spring. TAAA 2472-A, 5 1/4" long.
Old Mar 15, 2021 | 06:59 PM
F100wish's Avatar
F100wish
My truck is a 56 but not stock. The brake arm doesn’t have a hole for a spring (I could drill one no problem). But thank you for pointing out the original needed a spring, didn’t know that. I could use that spring for mine if need be, thanks again!
Old Mar 15, 2021 | 07:12 PM
Bessie's Avatar
Bessie
I'm working on this problem right now on my 54. My brakes are 100% stock and the return spring has a hole to go into to pull the plunger forward - no problem there. But, where does the other end of the spring connect? I stretched it to a hole in the frame without too much effort - but some, but the peddle does not pop back like it should when connected there. I can stretch is to another location about 4 inches further, but wow does that ever take some arm power. There must be a stock location. Any help?
Old Mar 15, 2021 | 07:25 PM
F100wish's Avatar
F100wish
Hope this helps
May not be a 53-56 but might be helpful.
Old Mar 15, 2021 | 07:35 PM
56panelford's Avatar
56panelford
I'm pretty sure there is a hole for the spring on the transmission / rear of motor cross member..
Old Mar 16, 2021 | 11:08 PM
Scottydog1001
I will try to remember to get one tomorrow.
Old Mar 17, 2021 | 07:27 AM
51fred's Avatar
51fred
Hope this helps
For future reference, the bottom photo is my 51. Should be correct for the 48-52.
Old Mar 18, 2021 | 09:42 AM
tonyguns's Avatar
tonyguns
this is helpful, thanks, now I just need to drill a hole somewhere in my transmission, or find a suitable place to rig it to. I've got an 80's AOD in my truck.
