Is anyone making their own locking hitch pins using grade 8 bolts
After a disappointing exchange with etrailer regarding locking antirattle hitch pins, I got to thinking, "why not make my own using grade 8 bolts". Next I started reading on the Internet and found my idea was hardly revolutionary. Not only was a fairly common, but recommended in a multitude of places. So given my propensity to fabricate, I was wondering if someone here may already be doing that and how it was working out.
Steve
Steve
Using grade 8 bolts is nothing new. Sure there is a ton of doomsdayers that claim they will fail but offer no proof or substance. Look at the amount of adjustable channel hitches that use grade 8 bolts. I like to make sure the shank of the bolt passes through the hitch completely with a little overage. This gives me the chance to run flat washers on both sides and then torque the nut down. I add a second nut and torque that as my lock and a pieceof glue lined heat shrink. I do the same at work but we weld the nut to the bolt to make it permanent. I build hitches in my free time and that's how I do them and there has never been wear or failure at max weight.
I have zero fabrication skills but decided to upgrade my hitch pin to this:
after an online discussion about using the hitch pin to attach my tow strap to the truck in the rear. I found an article written by a university discussing various hitch pins, primarily in agricultural scenarios and it said that when a hitch pin is secured on both sides of the trailer connection the actual strength is doubled.....
I went with the above because there were no threads to fool with.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Steve
I also read a very long piece on hitch pins directed at the farming community where some loads being hauled have huge weights. I read the same thing about securing the pin. What I am giving a try right now are locking pins that use the same key as the ignition. Reviews are very good and I would love to reduce the number of keys we carry for different locks.
Steve
Steve
How about buying this pin:
and the pin I mentioned above and use your fabrication skills to turn the end to match the pin and voila!
Using Grade 8 is a good idea, in fact if comes with a Grade 5 and its critical I will move to an 8.
All that said do not forget that you are working with 2 things: 1 Tension and 2 Shear. Shear is less than tension. Take away when you work in Shear then its a big or go home approach.
here is a table to offer up some data points
