Ford F150
Old Oct 27, 2003 | 04:21 PM
Hdawg's Avatar
Hdawg
Question Ford F150
I am working on a Ford F 150 4X4 351 . The truck starts good but will not turnoff when key is turned off. I have replaced ignition switch did not help. Checked wiring for breaks none found. The coil has power and sparks when ignition switch is off. I also noticed when turning off switch the interior lights brighten up, engine runs on. This is not dieseling.
Any one have some hints ?
Old Oct 27, 2003 | 04:27 PM
DuckRyder's Avatar
DuckRyder
Well, I'd guess that the wire to the coil is shorted somehow to B+. Its entirely possible that the ignition switch itself is at fault?
I must assume if it is an F-150 (and a 351) it isn't a 67-72? Does it have electronic ignition?
Did this problem just start after some other work?
Old Oct 27, 2003 | 05:11 PM
Hdawg's Avatar
Hdawg
1985 truck has electronic ignition. havent checked coil for short.
Bought the truck in this condition.
Ignition Switch is new, did that first.
foxman350
Mar 19, 2010 08:28 PM
whatthencuz
Jul 31, 2009 10:36 PM
Tricky Dick
Feb 12, 2004 08:08 PM
mep123
Electrical Systems/Wiring
Oct 23, 2003 07:31 PM
