fuel pressure test
Old Mar 13, 2021 | 06:34 AM
Listor's Avatar
Listor
fuel pressure test
So have some time to check a few things
fuel pressure is only 30 psi check it with 2 different gauges, idle 30 psi , WOT stays right st 30 psi
think I am going to just put a new fuel pump in have already done the hutch harpoon mod, pump is probably weak from god only knows how long they ran it with screens clogged!
Old Mar 13, 2021 | 07:00 AM
udsuth78's Avatar
udsuth78
Pull the regulator apart first. Lot more likely you have a weak spring or trash/gunk stuck.
Old Mar 13, 2021 | 07:06 AM
Walleye Hunter's Avatar
Walleye Hunter
I second this action unless you have more money than you need.
Old Mar 13, 2021 | 07:08 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Third...
The regulator or spring can do some strange things if it is not exactly right. I know this from experience.
Also, it is quick and easy to check.
Let us know what you find.
Old Mar 13, 2021 | 07:33 AM
Listor's Avatar
Listor
Originally Posted by Sous
Third...
consider it done, i will pull that 1st, although i do not have a replacement for it, Checked through my parts box no spring ! Want to check pressure from the current pump too
Old Mar 13, 2021 | 07:46 AM
Walleye Hunter
I don't recall anyone reporting having to replace a fuel pump due to weakness, it's more like they quit all together when they go.
Old Mar 13, 2021 | 07:53 AM
Sous's Avatar
Sous
FTE Emeritus
A while back RV tech had a weak pump that would allow his truck to start and idle, but not allow for any throttle input. He was stuck in a campground, was lucky enough to have his trailer moved by another camper and then able to replace the pump and be on his way.
I "think" I recall one other FTE'r that had a similar situation, but cannot say for sure.
I could not find the post/thread because the FTE search function is woefully inadequate and I was too lazy to use the Google method David recommended the other day.
Old Mar 13, 2021 | 07:58 AM
Dan V's Avatar
Dan V
You should have a Parker 60VLV-5 Vibra-Lok on hand for the fuel line fitting. You can source them from McMaster-Carr...50385K83
Old Mar 13, 2021 | 09:20 AM
Listor's Avatar
Listor
I do indeed have the removal tools, I will get around to that later as i need to go put in a water heater this morning!
Old Mar 13, 2021 | 09:41 AM
Dan V's Avatar
Dan V
It's the seal...not a tool.
Old Mar 13, 2021 | 04:29 PM
Listor's Avatar
Listor
sorry i misread what you were referring to!
Old Mar 13, 2021 | 04:33 PM
Listor's Avatar
Listor
i sure am glad i listen to you guys, I took apart the fpr, it was pretty gummy, cleaned it all up and put it back together, Not sure why i am reading 100+ psi, but i used to different gauges with the same results!
going to drive it a couple of days, going to order the fpr rebuild kit from riffraff, i felt no bucking at all on my short test drive ! YAY!
https://www.riffraffdiesel.com/fuel-...ild-kit-99-03/
https://www.riffraffdiesel.com/upgra...ing-kit-99-03/
Old Mar 13, 2021 | 05:01 PM
RacinJasonWV's Avatar
RacinJasonWV
I also replied on your other thread. High pressure is a sign the spring is not seated correctly in the FPR pocket. Time to take it apart and check again.
Old Mar 13, 2021 | 05:02 PM
udsuth78's Avatar
udsuth78
100 psi i is too high. I believe factory spec is 45 to 65 or 70. Something must not have gone back together quite right. I would double check your reading. Then may need to open her back up.
Old Mar 13, 2021 | 05:44 PM
Listor's Avatar
Listor
SOrry guys i double posted on my other tread i was worried my transmission was going, I am on the right train now, thinking it's fuel related , I agree i will have to open it up and double check that the spring seated correctly! Wind is howling and COLD AF, so i was a little rushed putting it back together!
if i could get someone to kill the other thread that would be awesome! https://www.ford-trucks.com/forums/1...on-issues.html
