HELP!!! Electrical gremlins
Old Mar 12, 2021 | 09:20 PM
1966F100SC's Avatar
1966F100SC
I went out to start my truck after it has been sitting for about 10 hours in a school parking lot and it fires for about 5 seconds and then quits. It just clicks one time after than and then I have to pull battery cables off and then again it clicks one time when the key is turned.
Relay on fender is new, so are battery cables. I checked ground at engine and at starter and cleaned those but it didn’t help. Tried jumping the relay with a wrench and nothing (remind me how to do correctly please)
anyway I do not have the time to keep fighting this tonight and have to leave it overnight. I would really appreciate it if anyone that has any suggestions at all to post real quick, that way in the morning I can just go through all comments and try one by one. Also if anyone has more questions I will get back to them by morning. Really need to get this thing out of the parking lot. Thanks everyone!!
Old Mar 12, 2021 | 10:17 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Have you load-tested the battery? Starter tests good?
Old Mar 12, 2021 | 10:45 PM
Oliver Harwood's Avatar
Oliver Harwood
By fire do you mean the engine runs on its own for 5 seconds then quits? If yes, then likely fuel related issue. If it isn’t running at all on its own, or really in any case, check for spark. Never hurts to pop the distributor cap and see what you see.
Old Mar 12, 2021 | 11:41 PM
1966F100SC's Avatar
1966F100SC
I’ve not load tested it. But I will tomorrow. I’ll pull battery and take it to a parts store.
it’s not fuel related because after it shuts off it won’t even crank. It’s obvious an electric issue but I don’t know where. Electrical is not my friend like mechanical knowledge is, more or less.
It did this earlier this week but at one point all of a sudden just started working again. But now I’m back to where I started. Clueless. I will try jumping tomorrow. I know the battery is charged but don’t know about the load.
I believe the click I hear is the relay on the fender. Could it be starter related?
Old Mar 13, 2021 | 08:16 AM
lizardman1's Avatar
lizardman1
Starters can definitely be intermittent especially when heat soaked.
Old Mar 13, 2021 | 08:17 AM
Crop Duster's Avatar
Crop Duster
Could be. These Ford direct drive starters take a lot of amps to get them engaged and turning. It wouldn't hurt to take the starter with you when you take the battery to have it checked. I've seen them with the bushings so worn that the armature was rubbing on the field coils and they would still work as long as the battery was new. But at that point it's just a matter of time until it shorts out and dies.
Old Mar 13, 2021 | 10:45 AM
1966F100SC's Avatar
1966F100SC
Well the Autozone couldn’t load test the battery. But I have a second starter known to be good, I may swap.
here’s where the issue is that I found:
I got it started but when I went to turn on the lights it died. And did it a second time. And same thing, when I turned lights on it died. Maybe a bad switch? I have another from a parts truck I may try. It seems like ignition is grounding out
Old Mar 13, 2021 | 11:04 AM
Crop Duster
Sounds like the bat is nearly dead and it isn't charging. Check the bat voltage before you start it. Get it started and check it. Should be 13.5 + running.
Old Mar 13, 2021 | 02:06 PM
1966F100SC's Avatar
1966F100SC
Battery load tested at a Walmart checked out good. Runs at 13.8v and not running it reads 12.62v
battery is all good
Old Mar 13, 2021 | 02:59 PM
lizardman1's Avatar
lizardman1
So does the truck stall now with the lights turned on?
Old Mar 13, 2021 | 03:21 PM
1966F100SC's Avatar
1966F100SC
Intermittently yes. Which makes me think it’s some electrical connection. But it doesn’t make sense as to why it does it with the light switch.
I am going to pull both the ignition switch and light switch off and clean them and make sure that there isn’t any corrosion.
anything else I should check while I’m at it?
Old Mar 13, 2021 | 05:07 PM
Thunderkiss1965's Avatar
Thunderkiss1965
Every ground you can find. Then add a few more.
Old Mar 13, 2021 | 06:11 PM
1966F100SC's Avatar
1966F100SC
Battery to engine to starter. Engine to frame. Engine to fire wall. Firewall to gauge cluster.
maybe add one from fire wall to dash? What else
Old Mar 13, 2021 | 06:57 PM
ibuzzard's Avatar
ibuzzard
You mentioned the problem seems to occur upon turning on your headlights, I think. If you think you’re having a short to ground through the headlight switch - change it. They are cheap and easy to change. You said you have a known good one?
Old Mar 13, 2021 | 09:46 PM
1966F100SC's Avatar
1966F100SC
Well I have another. From a parts truck, don’t know if it is good. I am not home anymore, I was just back to get the truck to the house, so while I’m away I would figure I’d ask here to see who else has any suggestions.
but yes, the plan is to switch it out and see if the symptoms persist
