These the right hammer locks?
Old Mar 12, 2021 | 06:34 AM
Frank79's Avatar
Frank79
I want to get a pair of hammer locks. I currently have a Stainless Steel 316 Bow Shackle 5/8", but the working load is only 3850 lbs.
Are these the right ones to get?
Trailer Towing Safety Chain Connector Link 13mm(1/2''), 5.3t (11600 Lbs) Loading. (Set of 2)
Amazon Amazon
Old Mar 12, 2021 | 06:50 AM
pig9r's Avatar
pig9r
Yes those will work. I bought these. I don’t know the difference but they are rated a little higher. Good seller also. They can be a pain to get started. I used a ball joint press to get the pin seated in the collar then hammered it through.
Amazon Amazon
Old Mar 12, 2021 | 07:51 AM
Frank79's Avatar
Frank79
I read folks were grinding the pin to a point on one end to give an easier start then slamming it home with a hammer
Old Mar 12, 2021 | 08:04 AM
f350larry's Avatar
f350larry
I pressed mine together with a beefy 6" C-Clamp. Much easier than using a chunk of wood to prop the link up and then beating with a hammer.
Old Mar 12, 2021 | 08:05 AM
f350larry's Avatar
f350larry
Old Mar 12, 2021 | 08:16 AM
winglesss's Avatar
winglesss
What is the location and purpose for these parts?
Old Mar 12, 2021 | 08:33 AM
Captain 40's Avatar
Captain 40
I bought a set of these:
Amazon Amazon
They are 1/2 in. despite the picture showing 3/8 in.
They went together with just a few firm blows with a hammer, no grind, no issues.
They aren't painted though, so I put a couple heavy coats of black Rustoleum on them first.
Old Mar 12, 2021 | 09:09 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Guys too scared to grind down the hitch loops to use normal safety hooks.
Old Mar 12, 2021 | 09:16 AM
cpobst's Avatar
cpobst
This is what I did, it didn't take much.
f350larry's Avatar
f350larry
Absolutely. Oh, and probably people that are not interested (or too scared) in modifying a trailer that they rent or borrow. So yeah, good one.
Old Mar 12, 2021 | 09:18 AM
Bullitt390's Avatar
Bullitt390
Modify the truck hitch not the trailer.
Ford's hitch is a dumb design either way.
Old Mar 12, 2021 | 09:21 AM
winglesss's Avatar
winglesss
This doesn't permit normal chain hooks to grab?
Old Mar 12, 2021 | 09:26 AM
f350larry's Avatar
f350larry
Gotcha, thought you were saying to grind the safety catches on the chain hooks... I've seen others suggest that in the past. And we do agree that the design is dumb.
Old Mar 12, 2021 | 09:42 AM
cpobst's Avatar
cpobst
The problem I have is the spring clips that prevent the hooks from coming off wouldn't close. I did some grinding on the bottom of the face where it extends down under the holes and now they work fine.
Old Mar 12, 2021 | 10:44 AM
Bullitt390's Avatar
Bullitt390
Nope. Either clearance that lip on the bottom or do the shackles like people keep suggesting.
