Rubber Trim Insert
Old Mar 12, 2021 | 01:32 AM
MrGGermany's Avatar
MrGGermany
Rubber Trim Insert
Hey all,
Has anyone gotten any good, lasting results reconditioning the rubber inserts in the upper molding on our trucks? What did you use?
I appreciate any tips.
Old Mar 12, 2021 | 08:57 AM
440 sixpack's Avatar
440 sixpack
Not a lot you can do with plastic or rubber except replace it or refinish it. you could use SEM color coat and I'm sure it would look good for a long time if you keep it stored inside. if you leave it outside it may not last as long I've never tried that.
Old Mar 12, 2021 | 10:53 AM
MrGGermany's Avatar
MrGGermany
So, paint is my best option? I was hoping there was maybe an oil based (or any) product that would make it look blacker and hold for a summer or so.
Old Mar 12, 2021 | 11:29 AM
Mark8man's Avatar
Mark8man
I've used this but there are many similar products on the market that might offer a same or similar result. How bad a condition is your in? If just discolored this should work but may need reapplied every few weeks depending how much sun it gets.
Amazon Amazon
Old Mar 12, 2021 | 12:48 PM
HoustonDave's Avatar
HoustonDave
The look of faded plastic can be improved with a heat gun (maybe a hair dryer if you have one that gets really hot). Never tried that on rubber... think I would try a test section first. Be careful not to apply too much heat.
Old Mar 12, 2021 | 03:00 PM
MrGGermany's Avatar
MrGGermany
https://www.amazon.com/Meguiars-Ulti.../dp/B0055PD1H4
It's not horrible. Just a little faded. I got fresh paint last fall and want the chrome and rubber to look a little better as well. Thanks for the link.... I'll see if I can get that here.
Old Mar 12, 2021 | 03:04 PM
MrGGermany's Avatar
MrGGermany
I DO have a good one, but I'm wary of using it on there. On my daily driver sure, but on The Beast I don't want to screw it up!
Old Mar 12, 2021 | 05:13 PM
scottscott's Avatar
scottscott
The insert is basically plastic, so use plastic polish. If it is really grimy, use polishing compound, followed by plastic polish.
This will darken the color & make the insert really slick.
Old Mar 12, 2021 | 11:43 PM
MrGGermany's Avatar
MrGGermany
Thanks for the idea.
Scoop531
29
Dec 10, 2015 01:06 PM
AZRRC
Feb 16, 2014 09:25 AM
flkeysff
Sep 10, 2013 06:59 PM
KiwiFord
Jun 10, 2010 07:35 AM
jmadsen
Jun 2, 2010 11:24 AM
