Instrument panel fuse
Old Oct 27, 2020 | 07:36 PM
dstraw's Avatar
dstraw
I am having issues finding the correct 2amp small fuse for the gauge cluster in my 1974. Any know a part number or link?
Old Oct 27, 2020 | 08:51 PM
Idaho Highboy's Avatar
Idaho Highboy
Veteran: Navy
I don't have a 2A fuse in my box - that I'm aware of... Where is this cluster fuse located (e.g. with the rest down by the driver's feet)? Hope we can get you an answer.
- IH
Old Oct 27, 2020 | 08:55 PM
dstraw's Avatar
dstraw
Old Oct 27, 2020 | 10:02 PM
dlburch's Avatar
dlburch
that one should be the AGA size...most parts stores should carry them.
Amazon Amazon
Old Oct 28, 2020 | 02:29 PM
dstraw's Avatar
dstraw
Thanks! They only had 6 amp, my lights are working now, any issue with running the 6 amp?
Old Oct 28, 2020 | 04:28 PM
dlburch's Avatar
dlburch
the answer is, it depends...there could be potential issues if any part of that circuit (such as copper traces on the instrument cluster backing) can't handle 5.99999 amps until the fuse blows, those parts of the circuit then become the "fuse" so to speak and could smoke before the fuse blows...I'm sure there is a reason it was designed to be 2 amps (or 3 amps according to some sources)...but you will be ok as long as nothing shorts on that circuit...
Old Oct 28, 2020 | 05:13 PM
68Flareside240's Avatar
68Flareside240
Good advice above. Any electrical supply house should have one. Amazon and online do as well. When these trucks were new, no doubt the wiring could take 6 amps through it. Forty plus years of corrosion and hack mechanics splices could have changed all that, and the weakest link is wherever it is.
Old Mar 13, 2021 | 07:41 AM
CombatSurfer's Avatar
CombatSurfer
I can't find the darn thing in a store anywhere. Ordering from NAPA along with several other fuses to have on hand when they go bad.
Old Mar 13, 2021 | 08:32 AM
dstraw's Avatar
dstraw
Got mine on Amazon.
73stang
Oct 21, 2016 09:21 AM
cyclone3565
Nov 4, 2013 04:42 AM
stang302
1997 - 2003 F150
Sep 27, 2008 06:41 PM
