Rocker Nut Installation
Old Mar 10, 2021 | 10:55 PM
FlyJSH's Avatar
FlyJSH
Veteran: Navy
I didn't pay enough attention when I removed the rocker arms, and now I don't know which way they face. The nuts each have a flat face and a semi domed face: which mates with the Valve Rocker Arm Fulcrum and which to the jam nut?
Thanks
Old Mar 11, 2021 | 10:28 AM
pmuller's Avatar
pmuller
You have three pieces: Rocker arm, pivot ball and nut.
The pivot ball goes into the rocker and the nut goes on top of the flat side of the ball with the flat side of the nut facing down.
Old Mar 11, 2021 | 11:38 AM
FlyJSH's Avatar
FlyJSH
Veteran: Navy
Thanks! interesting thing is my head has the rocker, pivot ball, nut and second nut that was used as a jam nut. I wonder what the previous rebuilder's reason was for adding the second nut.
Old Mar 11, 2021 | 12:27 PM
pmuller's Avatar
pmuller
The 83 head uses non adjustable rocker arm studs that have a 5/16" thread and a 3/8 shoulder.
The 5/16" nut gets torqued down on the 3/8" shoulder and should not need a second locking nut. Of course the second nut won't hurt anything.
Did you get the rotating exhaust retainer situation straighten up?
Old Mar 12, 2021 | 12:33 PM
FlyJSH's Avatar
FlyJSH
Veteran: Navy
Thanks, much appreciated.
Yes, I found 6 NOS retainers for $14 delivered. They fit like gloves, and now I have 5 good, used spares.
Old Mar 12, 2021 | 09:30 PM
FlyJSH's Avatar
FlyJSH
Veteran: Navy
Two steps forward, and one step back... or Why I should listen to that little voice when it says "It's time to stop."
When I went to torque the nuts, I was a very good boy and checked the manual. The little chart showed standard torques for fasteners from smallest to largest. I checked the socket for the nut size and consulted the chart. 9/16" nut; chart says 85 ft/lbs for 9/16" fasteners. It seemed like a lot, but even after checking again 85 ft/lbs was my number.
Did you catch my error? 9/16" Socket, but the threaded part was 5/16". The torque for 5/16" is 18 ft/lbs.
So, the good news is the stud did NOT strip...
The bad news is ... it broke.
So it is off to order studs. Then to figure out a way of pulling the old one and replace it while I wait on the mail.
"I told you it was time to quit," said the voice.
"Shut up you gosh darned forking ice-hole!"
Old Mar 13, 2021 | 09:35 AM
pmuller's Avatar
pmuller
You will need to thread the 3/8" part of the stud so you can get a nut on it to pull on.
MELLING MRDS943. you should be able to get one at the local parts stores.
Is the cylinder head off the engine?
Did you find the two locating dowels that go between the head and the block?
Old Mar 13, 2021 | 04:39 PM
FlyJSH's Avatar
FlyJSH
Veteran: Navy
So off with the head, and over to the machine shop? Or buy a jy head and start from scratch. or put it together and run it on 5. I would have been better off buying a remanufactured head
Sorry for venting; I'm a bit displeased with myself right now.
Old Mar 13, 2021 | 04:47 PM
FlyJSH's Avatar
FlyJSH
Veteran: Navy
Locator pins: I found a picture of them in a block. No, I haven't located any. Rock Auto is the only place that lists them for the correct year and engine... and the are backordered. At least I learned the size from them: 0.676" by 7/16". Made some calls and got the usual run around (does it have a/c?). Nobody seems to have them or really know what I'm talking about. maybe that is another vote for the jy.
I'm just soooooo p@ssed that I took the time to do some very mild porting only to see it up torquing a bolt.
Old Mar 13, 2021 | 05:22 PM
pmuller's Avatar
pmuller
You can take advantage of your situation if you want.
Now would be an ideal time to replace all the studs with screw in studs.
Or you can simply have the shop pull the broken stud and replace it with a new stud.
The replacement stud is the MELLING MRDS943 which you can get a local auto parts store.
Melling Rocker Arm Stud MRDS943 | O'Reilly Auto Parts
Or Summit
Melling MRDS-943 (summitracing.com)
Old Mar 15, 2021 | 08:57 PM
FlyJSH's Avatar
FlyJSH
Veteran: Navy
Or Summit
Well, at the going rate for machinists around me, a rebuilt head would be about the same cost as a rebuilt.
Old Mar 15, 2021 | 10:42 PM
pmuller's Avatar
pmuller
So what would you like to do?
Old Mar 16, 2021 | 08:25 PM
FlyJSH's Avatar
FlyJSH
Veteran: Navy
Sorry, my post was poorly phrased. I meant to say the cost of replacing them all would be more than a new one. I found a place that quoted $100 for the two bad studs, and I will get them replaced.
The owner of the shop seemed to take pity on me. He was looking at the broken stud and mumbled, "I wonder how this broke?" After I said, "I broke it." and recounted my stupid error, he chuckled, shook his head, and said, "Yeah, it happens." I got the feeling he was recalling some bonehead mistake he had made.
Old Mar 18, 2021 | 02:51 PM
AbandonedBronco's Avatar
AbandonedBronco
We've all been there, and done stuff like that! Welcome to the club.
It is frustrating though, especially since all it would have taken is maybe a double check, or a different thought.
If it were me, I'd have all the studs pulled and redone with screw in studs. I believe my machine shop asked for $125 to redo all of the studs with screw in studs, plus the cost of the studs, which were about $50 - $60. Don't cheap out on the studs, get ARP.
Keep in mind that if you go with screw in studs, you will have to adjust them manually, as they'll no longer be a simple torque down.
Otherwise, you can just have that stud pulled out and a new one pressed in.
Either way, you didn't ruin the head, just the stud.
Old Mar 18, 2021 | 08:37 PM
FlyJSH's Avatar
FlyJSH
Veteran: Navy
Thanks for Been There, Done That comment. I know it happens. I'm thinking of getting a tattoo of the bill to remind me to stop working when that little voice is talking to me.
Good news is I got the head back today: two press in studs for $106 by a company with a good reputation ( going hourly rate around here is 75/hour). The master/owner said it went well, and I think it looks good. While not clean enough for me to install it without a cleaning (I've come too far to cut corners), it was clearly done with cleanliness in mind.
I didn't want to go with screw ins because a rebuilt head is only about twice what you paid for the studs. My guess is the original head lasted 200, 000 miles. Actually, there was very little wrong with the head except for about two pounds of carbon. I'm not planning on hauling anything heavy and I've done the porting, so the old gal should be make it to half a million miles or my demise, whichever comes first.
