Clarification on upfitters
Old Mar 14, 2021 | 09:51 AM
Dan1954's Avatar
Dan1954
Originally Posted by ibeb
If you are just looking to hook up a dash cam by the mirror, this is about as simple as it gets:
https://www.amazon.com/dp/B088P4VFQ7...p_mob_ap_share
product description says not compatible with vehicles with rear backup camera LCD displays. Not sure if they mean doesn’t work with trucks with backup cameras, LCD displays or both. Or backup cam displayed in the rear view mirror. How is you’re truck equipped?
Old Mar 14, 2021 | 09:57 AM
ibeb's Avatar
ibeb
I have this in my 20 F350 Lariat see window sticker for options.
Old Mar 14, 2021 | 10:15 AM
mtnguy's Avatar
mtnguy
After skinning up several knuckles and getting a crick in my back trying to get a connector on the pass thru wires, I am 1 of the members that ended up just going thru a grommet in the floor pan. I ran 4 wires from my 2017 (drivers side relay box back then) relay box in a wire loom across the top of the firewall, down to the frame, then to the grommet next the passenger side seat. From there I ran the wires to a space behind the glovebox, added a female cigarette socket to each, and ran my accessories to those. Using the cigarette sockets allows me to switch out the my accessories to whatever upfitter switch I choose, plus my dash cam has some weird voltage and needs the cigarette socket to convert that.
Old Mar 14, 2021 | 10:30 AM
Frank79's Avatar
Frank79
Originally Posted by Colemany
I decided the same and have the center console so I popped the cup holder console trim up, ran my dash cam wire under it into the 12v socket in the console.
Theres a 12v plug in the center console?? I need to go back and look.
Old Mar 14, 2021 | 11:47 AM
Colemany's Avatar
Colemany
Mine is a 2021, here is a pic of the plug and dash cam wire.
Old Mar 14, 2021 | 01:23 PM
Frank79's Avatar
Frank79
LMMFAO. Just looked and yep, Ive got a plug also hahaha.. Guess I need to get some glasses
Old Mar 14, 2021 | 01:25 PM
Frank79's Avatar
Frank79
How did you end up running the wires? Can you give me a wider view? Right now Im plugged into the 12v near the dash controls and hate it
Old Mar 14, 2021 | 03:27 PM
Colemany's Avatar
Colemany
I don't have any other pics and it's raining right now. I was able to fish a wire where the console trim (while popped up) meets the dash to come out at the bottom near the floorboard. Was then able to pull the dash cam wire up from behind the glove box under the console trim and into the console.
eminence1963
Jun 8, 2020 11:47 AM
06SD250
Oct 10, 2010 05:17 PM
jonsk
Sep 1, 2008 08:42 PM
XxfirmanxX
Electrical Systems/Wiring
Dec 5, 2004 07:39 AM
wickdgt
Nov 2, 2003 02:49 PM
