Couple quick questions on engine pull
Old Mar 10, 2021 | 07:30 PM
Flecker's Avatar
Flecker
So I'm gettin ready to yank this thing and have a couple things I'm wondering... (I typically work on Jap crap, nothing this big).
I want to tug just the block out and leave the trans/ transfer case for now until I roll the cab back out of my way ( it's a space issue). Anyone know a good way to leave the trans in? Just put a jack under the front? Looks like the bulk of the weight will be towards front, yah?
AND, if I have to yank it all in one fell swoop~ any idea on the weight of the c6/ np205 combo? The transfer case looks to be a HEAVY pig.
Thanks in advance!
Old Mar 10, 2021 | 07:35 PM
FordEdsel75's Avatar
FordEdsel75
I just always leave a jack under the transmission.
Old Mar 10, 2021 | 08:11 PM
440 sixpack's Avatar
440 sixpack
a jack under the transmission is good as long as you don't want to move it. I have used a jack then put a come along under it to hold it up after I was done.
I'm not sure what the whole combination would weight but it would be a lot. at the very least I'd pull the T case if you decide to do it all. it will be so tail heavy you're going to really fight it.
Old Mar 10, 2021 | 08:19 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
I had a bar that went across frame rails and put a bolt thru two of the tranny mounting holes and let bar rest on frame, used a jack while pulling engine, then added bar and removed jack.
Old Mar 10, 2021 | 08:48 PM
Flecker's Avatar
Flecker
Awesome ideas guys... thanks. My hoist is rated for 2k. I know it wouldn't max it out, it's just a space thing. No room in my shop to swing the whole kit and kaboodle out. And yah, the transfer is fricken heavy. Too heavy I think for a big *** pull like that. I'll take the block first, then roll the cab back and tug the trans combo out. Prolly the easiest.
Old Mar 10, 2021 | 10:13 PM
fishjosh's Avatar
fishjosh
I have a block of wood under my trans and a ratchet motorcycle strap under the block hooked between the frame rails holding mine
Old Mar 11, 2021 | 08:19 AM
ranger140892's Avatar
ranger140892
Grumpy goat
Yep, all good. I've used a cable. And used a piece of rebar once. Once, for an unlike engine swap, I fabricated a fixed mount to the transmission, so I could keep my pinion angles the same with new engine. And yes, the transfer case is an unwieldy beast to maneuver. Much more so than than transmission.
Old Mar 11, 2021 | 08:58 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2...2..2 use a floor jack and hold it at the current angle for removal. Then when you need to move the truck, use a piece of angle iron across the frame, or a heavy duty ratchet strap. I like the 2 bolt idea in the housing also.
NP-205 is 130 to 140 dry weight. I know they will smash a finger tip in a quickness. Use your cherry picker once the cab is slide back.
Also are you using a carb attachment plate or the piece of chain diagonally (or the 4 short pieces and a leveler) using the bolt holes in the heads?
Old Mar 11, 2021 | 09:29 AM
Flecker's Avatar
Flecker
I have a home made carb plate that fits to the intake my friend made like 30 years ago or better (owns a shop down the road)... 1/2" steel plate with a loop welded on~ said he's pulled over a 100 engines with it. I was trying to determine the 1/2" bolts I will need to mount it? Guessing 1-1/4" or so? Was just gonna hit up the local Ace Hardware and get some grade 8's to cinch the plate down. Sound correct? I don't have a bar like yours. The majority of 4 bangers or 6's I have pulled were Toyotas and typically had hooks mounted to the engine (Or some tabs I bolted to the block to help yank them).
I'm guessing the plate for the intake is gonna leave the block a bit off kilter or something?
Old Mar 11, 2021 | 09:36 AM
77&79F250's Avatar
77&79F250
I know a lot of engines have been and will be pulled with a carb plate. I am not that trusting. I would depth check the bolt holes and get the longest you can use. A leveler sure makes it easy to tilt is one way or the other come install time. Especially when working by yourself. But a leveler will not work in a situation like this. Some FTE member got it out of there.
Old Mar 11, 2021 | 09:41 AM
440 sixpack
They should be 5/16" bolts usually. the length will depend somewhat on the thickness of your lift plate.
I use 1" grade 8 bolts then if needed I use washers to take up any slack. I want them in there good. I just snug them up too since there's no need to put additional stress on them . I'm sure 3/4" grade 5 bolts would do the job but it makes me feel better.
1bad67sbf
Nov 28, 2010 10:42 AM
wla6518
15
Oct 18, 2010 09:12 AM
rscotth
Dec 28, 2009 06:14 PM
Dru71
Jan 5, 2007 06:11 AM
buddhabronc
1978 - 1996 Big Bronco
Jun 7, 2006 09:19 PM
