emissions help
Old Oct 27, 2003 | 02:08 PM
1987rangerpu's Avatar
1987rangerpu
emissions help
i have an 87' ranger, 2.9L, 6 cylinder, electronic fuel injection, 5-speed manual transmission, two-wheel drive.
it had failed the mass emissions test with a hydrocarbon reading of 5.60 gpm.
since then i have changed the oxygen sensor which brought the reading down to 4.25, but the limit is 3.20.
what else can i change on the truck to bring the hydrocarbon reading down?
none of the emissions controls systems have been changed on the truck (other than the oxygen sensor) due to the fact that i bought it used last febuary.
any help would be greatly appreciated.
Old Oct 27, 2003 | 06:39 PM
wolfen's Avatar
wolfen
Welcome to FTE 1987rangerpu,
I the need to know is now, have you computer codes pulled for free at Advance or Auto Zone, 1st call to confirm!
__________________________________________________ __
‘90 Ranger XLT: 2.3L, EEC-IV, EFI, DIS, 2wd, Mazda 5sp 127K/mi
Old Oct 27, 2003 | 07:15 PM
black wolf's Avatar
black wolf
welcome to the FTE... what i always do is change my oil and filter pcv valve air filter and the spark plugs. did you check your thermostat and see if its working ok? sometimes they fail with the emissions too by over heating the engine. test your catalytic converter to see if its plugged at the shop ..hope this will help
Old Oct 28, 2003 | 05:51 AM
coolride's Avatar
coolride
I'm up in Canada and we have to do our emissions every other year. I just paseed and I bought the truck for 100 bucks. Mind you I put approx. 600 into it including a new converter. Along with what Black Wolf said, if you think you need a new converter put one on and try the night before the test put high octane gas as well. Also make sure timing is right on the money. My friend is a mechanic, he said FORDS are pretty good for emission tests. Let me know what happens.
Old Oct 28, 2003 | 07:08 AM
wolfen's Avatar
wolfen
Hi ya group,
Just replaced my thermostat because I pulled a code 21 (ECT) on my EEC- IV / PCM. Well...to make this short, I had a rusted hose clamp that busted and this stopped the engine from getting up to operating temp!
Summary: Don't always go for the most expensive problem! This one was worth 50 cents and 5 min in time!
As for emissions, I'm looking forward to it! I have 8 plugs in my 2.3L and I'm curious to see the readings; being the new owner and all!
Old Oct 28, 2003 | 09:02 PM
1987rangerpu
i allready changed the oil and oil filter along with the plugs and wires. the thermostat and timing are all of, too.
now im gonna replace the pcv valve and air filter. then next week im gonna take to get the converter tested.
thanks for all the help.
Old Oct 28, 2003 | 09:03 PM
1987rangerpu
i allready changed the oil and oil filter along with the plugs and wires. the thermostat and timing are all of ("ok"... typo), too.
AZ_Tuc250
Nov 27, 2014 08:11 PM
gobblerman
96
Jul 31, 2010 01:05 PM
gov2mod
1978 - 1996 Big Bronco
16
Dec 31, 2004 12:44 AM
SoCalDesertRider
15
Dec 7, 2004 10:19 AM
hartattack
General Automotive Discussion
Mar 18, 2004 03:38 PM
