Should I buy????
Old Mar 8, 2021 | 01:47 PM
Devin Marshall's Avatar
Devin Marshall
4wd Low
Should I buy????
I have been looking at a 1987 F250 single cab with the 6.9l diesel 104k miles 4x4. Many new parts and a rebuilt transmission 2000 miles ago.
What should this truck go for?
Old Mar 8, 2021 | 03:44 PM
DarkOverCast's Avatar
DarkOverCast
2-5k here in Texas mainly dependant on the cosmetic condition.
It probably doesn't have an overdrive trans so that kills the value for most people. Good candidate for a zf5 swap though, if you can find one or even find one reasonable.
I'd pass if it's c6, 4speed I could live with if it had 3.55 gears..
Old Mar 8, 2021 | 06:54 PM
jjqllc's Avatar
jjqllc
Hey now, my truck ain't no slug. C6 +3.55's
Old Mar 8, 2021 | 06:56 PM
DarkOverCast
Never said it was, just most don't like em since the lack of overdrive.
I'd take a c6 over an e40d
I really wish Ford had made a heavy duty AOD
Old Mar 8, 2021 | 06:58 PM
jjqllc's Avatar
jjqllc
I wish I had a E4od. Or the zf5. C6 is ok, but at 65-70 you can't hear yourself think.
Old Mar 8, 2021 | 07:09 PM
DarkOverCast
Being 4x4 I imagine it's hard to find a gear vendors.
Old Mar 8, 2021 | 07:32 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
diesel C6 is different from the Gasser mostly the Torque converter and the governor they work pretty good with tall gears on the highway, but I was always looking for the extra gear
when towing hard with E4OD may as well be same as C6 as ya don't want to use OD... Tall Gears still best .. love my type 69 rear end with E4OD and I haul some weight.... towing not so much any more since I sold the old Welcraft Airslot
Old Mar 8, 2021 | 07:35 PM
jjqllc's Avatar
jjqllc
I don't have the time now. I'd do a zf5 swap. My work season is starting up (I'm a mason), and I won't have time for that stuff now. To the OP, price is dependent on the shape of the underside--rust and rot. My 87 has 97k miles but the cab mounts were bad. I just put in 12 hours replacing the radiator core support today and I'm questioning if it's worth it anymore. If it's going to make you money, and runs well with little smoke I'd say 2k -4k. If you're going to do alot of highway driving, I'd pass like DOC said.
Truckie256
Dec 30, 2014 05:18 PM
jonesy5.0
May 24, 2009 04:42 PM
upnorthman
Mar 25, 2003 12:59 PM
OSUCBY26
Dec 3, 2001 02:51 PM
