Air dam
Old Mar 6, 2021 | 12:25 PM
Bob King's Avatar
Bob King
Air dam
Can anybody tell me which ford f150 air dam to put on my f250 for more clearance or an aftermarket manufacturer?
Old Mar 6, 2021 | 12:50 PM
fordman19762003's Avatar
fordman19762003
I don't believe the f150 air dams will work. Most guys are either buying the 2wd super duty piece or one from a Tremor model if you have a '20+. You can also cut your existing dam down, that's what I did and it turned out good.
Old Mar 6, 2021 | 01:06 PM
Kellem's Avatar
Kellem
Agree, most are getting the Tremor valance or cutting their own.
Old Mar 6, 2021 | 01:18 PM
Pugga's Avatar
Pugga
Cut your own or get one from the 2wd model. I am not aware of any F150 air dams that can be used.
Old Mar 6, 2021 | 01:35 PM
Squirrel13's Avatar
Squirrel13
Tremor valance are on national backorder. Mine has been on order since end of Jan
Old Mar 6, 2021 | 01:58 PM
T. Banning's Avatar
T. Banning
I installed the 2wd model on mine as well as removing the Prius catchers. The F150 air dam will not work, it is completely different.
Old Mar 6, 2021 | 05:13 PM
Bearwhiz's Avatar
Bearwhiz
Can anyone tell me what the air dams are actually for. I usually just take them off and pitch them in the garage.
Old Mar 6, 2021 | 05:20 PM
mtnguy's Avatar
mtnguy
It cuts down on turbulence under the truck, resulting in better fuel mileage. (Supposedly)
Old Mar 6, 2021 | 05:26 PM
Crotchety Ford truck only's Avatar
Now that's a garage..............
Old Mar 6, 2021 | 08:50 PM
Ultratravler's Avatar
Ultratravler
T Banning, How much did the 2 wheel drive model cost? Thanks.
Dave
Old Mar 6, 2021 | 09:38 PM
T. Banning's Avatar
T. Banning
Dave
I'm a Ford employee, so I get a discount. I'm trying to remember, I'm thinking I was just over $100.
Old Mar 6, 2021 | 09:40 PM
T. Banning's Avatar
T. Banning
40x50, but not big enough. No matter how big you build them, you always fill them up!
Old Mar 7, 2021 | 01:40 AM
23mikey's Avatar
23mikey
Also creates a "low pressure" area under the engine area enhancing the cooling air flow thru the radiator stack.
Old Mar 7, 2021 | 02:15 AM
whitedar's Avatar
whitedar
I did the 2wd valance and prius catcher removal a month or two ago. Looks so much better. IIRC, the Tremor valance won't fit the 2017 F250 bumper (not sure what year you have).
-Brian
Old Mar 7, 2021 | 06:41 AM
rprice32's Avatar
rprice32
I trimmed mine 3 weeks ago. Looks better to me.
