Air dam
Old Mar 10, 2021 | 01:01 PM
  #31
Pugga's Avatar
Pugga
Originally Posted by slownsy
The so-called Prius catchers is a safety feature to prevent small cars disappearing under your trucks, and I don’t se any purpose for removing them unless for fitting something else there.
Frank.
When you go with the shorter air dam, they end up being exposed and give the truck a gap tooth look. So, you can either cut them down or simply remove them. I'd imagine most just remove them since it's only 4 bolts and done.
Old Mar 10, 2021 | 03:28 PM
  #32
MKrenn's Avatar
MKrenn
And BTW, those are not fun to remove. A ratcheting 18mm wrench I believe would work best. I used an impact with a u-joint & socket. That worked but wasn't easy getting the impact up in there....
junkkingranch
WTB - Parts & other
Jun 10, 2017 06:32 PM
StreamlineGT
Sep 17, 2007 01:39 PM
sixpack664
Oct 28, 2006 09:03 AM
