FICM Time delay kill switch
Old Mar 5, 2021 | 08:59 AM
JimmyRoach's Avatar
JimmyRoach
Time delay relay start countdown with S1 switch connect 12 volts to pin 15 of TD relay.
After time is expired pin 87 is connect to 12 V and the Aux relay energized breaking the ground connection
between pin 30 and 87a of the regular automotive relay.
S1 can be any type of switch.. even a magnetic type switch that is normally open with magnet keeping the switch open.. but remove the magnet and then the switch apply 12 volt to pin 15
Time delay relay is approximately over $ 50.00 from the MRS -electronics company..
with this kill switch allow driver to leave vehicle running for x min. How many would be interested in purchasing this already prewired with sockets for both relays? then you purchase the relay and install
Norris McCarty
Dec 31, 2018 07:05 AM
jniolon
May 25, 2018 12:51 PM
mh34444
Electrical Systems/Wiring
Oct 1, 2011 11:47 AM
884x4broncoII
May 28, 2008 07:42 AM
