Sponsored by: Real Truck
Bluetooth OBD2 scanner app
Old Mar 4, 2021 | 07:06 AM
1Truck's Avatar
1Truck
Hello guys,
I know this question has been asked before but all answers I have found are 2 or more yrs old.
What scanner app do you use with your BAFX dongle? I am currently using torque pro but would like to check out some alternatives.
Thanks in advance for your suggestions!
Old Mar 4, 2021 | 10:24 AM
Overkill2's Avatar
Overkill2
Go in the 6.7 diesel section and you'll see there are threads on the FORscan app. It's software that can be used on a laptop or your phone. Torque Pro is good also. There's threads on that as well.
Old Mar 4, 2021 | 07:44 PM
1Truck's Avatar
1Truck
Thank you for your reply. Last night I ordered a usb obd2 with ms/hs scan switch to use with forscan on my laptop. I will check out the section you mentioned. Thanks again, I appreciate it! My only worry is that I won't be able to do much more than I can with my existing 3 different scanners as the truck is obd1 based with obd2 connection. I believe this may be due to it originally being a fleet truck(?).
Old Mar 5, 2021 | 07:37 AM
Overkill2's Avatar
Overkill2
No problem. Glad to help out. Good luck.
eyyu
15
Dec 3, 2018 12:56 PM
jimdad07
Jul 10, 2016 08:59 AM
timmytoes
Dec 13, 2015 12:23 PM
TheCurtster
Apr 12, 2014 12:25 PM
madhatt
Feb 20, 2014 03:32 PM
