Pedal command?
Old Mar 11, 2021 | 09:05 AM
  #46
MKrenn's Avatar
MKrenn
Originally Posted by B-ManFX4
Thinking that if the Banks unit fails it will only affect the throttle is a pretty big assumption on your part. A Banks unit connected to the ODBII port is also connected to the high speed CAN bus - which could affect almost EVERYTHING in the truck. The Banks unit controls the throttle position via the CAN bus and the PCM - if it were to go "haywire" there are many things on that CAN bus that would be affected.
The Pedal Commander is connected between the pedal position module and the PCM - it does not connect to the CAN bus. If it were to fail it might make the pedal inoperative - but that is where it would stop. The Pedal Commander is powered via the voltage supplied by the PCM and the outputs on the PCM are current limited. Even if it failed as a "short" (highly unlikely) it would not damage anything.
All things equal, would I worry about either unit failing ? Not any more than any other solid state device in the truck - which there are hundreds.
Hey man. You buy what you want and I'll buy what I want. I just pointed out what I like about the Banks. Geezus.... I knew if I said something a liked, someone would try to knock it down. I guess i'm done with this thread....
Old Mar 12, 2021 | 06:24 AM
  #47
B-ManFX4's Avatar
B-ManFX4
And I just pointed out that your assumption of failure is not the only scenario that is possible. Sorry I hurt your feelings by posting up other failure possibilities.
Old Apr 1, 2021 | 11:42 PM
  #48
alumizilla's Avatar
alumizilla
I'm looking to confirm something. For those who have actually experienced a real world Pedal Commander failure, how did the fault manifest itself (DTC codes, driving behavior, etc) for you? Failure seems to be rare, and that's a good thing, but I need some data to check something. Thanks
dkalt
Apr 16, 2020 12:33 PM
n20
Mar 29, 2010 02:34 PM
CruisnPhantom
Feb 14, 2004 09:04 AM
Dwights
Mar 23, 2002 07:48 PM
