Sponsored by: Real Truck
2008 Leaf Spring Conversion
Old Mar 3, 2021 | 12:22 PM
robjs111's Avatar
robjs111
Planning on 2008 leaf spring conversion on my 2004 f350. My question is can I use a set of 2017 leaf springs for conversion? 2008 to 2020 leaf springs basically the same? All i need to deal with is move front hanger forward and relocated e brake cable.
Thanks.
Old Mar 3, 2021 | 12:54 PM
Eaglescout94's Avatar
Eaglescout94
The only big difference I’m aware of is 11+ you either run the u bolts round side up or remove the top plate so you can run u bolts with the round end on the bottom.
Old Mar 3, 2021 | 02:07 PM
robjs111's Avatar
robjs111
Copy that.
As far as I know 2008 and up leaf springs are essentially the same.
Thanks
Old Mar 10, 2021 | 10:05 AM
99.5_Superduty's Avatar
99.5_Superduty
U Bolts seem to have been from bottom up pretty much forever. What is the benefit that Ford saw with flipping them and running them from top down?
I believe the 2017+ may use a larger bolt that goes through the spring to attach it to hanger, but you can simply drill out your hanger to the correct size.
Old Mar 10, 2021 | 03:14 PM
Split rims's Avatar
Split rims
Sfbowie
Jul 3, 2019 02:10 AM
octaneforce
May 4, 2010 09:50 PM
FordmanShane
Apr 18, 2010 08:36 PM
1952
Oct 13, 2003 02:31 AM
