What choke?
Old Mar 1, 2021 | 07:43 AM
crabdad's Avatar
crabdad
What choke?
How do I know for sure what choke I have ? All electric or electric assist? Need to figure out my heat riser. Love this site by the way.
Old Mar 1, 2021 | 08:04 AM
FordEdsel75's Avatar
FordEdsel75
That's electric. You connect switched 12v and it will work. Unscrew the 3 screws and turn it left to have it open slower and turn it right to open faster. Tighten the screws and check fast idle speed when done.
Old Mar 1, 2021 | 08:15 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Pretty sure you can connect it here for the proper power. I believe this is the OEM choke power point.
Old Mar 1, 2021 | 08:43 AM
440 sixpack's Avatar
440 sixpack
Yes electric. if it's bad you can buy a new one most anywhere.
Old Mar 1, 2021 | 09:37 PM
F-250 restorer's Avatar
F-250 restorer
I'm curious. Was that carb originally a hot air/vacuum choke? The reason I ask is because of that metal half/round bracket that hangs in front of the choke. That is for the heater hose to ride in. Usually you find those on hot air chokes, not electric ones.
Old Mar 28, 2021 | 12:34 PM
crabdad's Avatar
crabdad
I assume it was
Old Mar 29, 2021 | 10:53 AM
beartracks's Avatar
beartracks
You need full 12v. Original was lower voltage If I remember correctly.
Old Mar 29, 2021 | 11:02 AM
F-250 restorer
I would take the cover off and make sure the vacuum passage is well plugged.
Old Mar 30, 2021 | 03:10 AM
1TonBasecamp's Avatar
1TonBasecamp
I see a bolt in that rear angled fitting. Looks like they plugged it that way, but if your threads are still good you can grab a brass/stainless cap that will fit right over it. I've done it on several carbs over the years when the chock stove setup fell apart.
Yours looks like a Holley choke spring on a stock carburetor. So yes, originally you had both the choke stove fittings from the stock exhaust (or intake manifold depending on which engine) and the heater hose to help keep things going. Perhaps they wanted to get rid of it all, or it deteriorated, or they got headers and changed hose routing or whatever. Maybe the old choke spring died, or they swapped to the Holley because all that other stuff was no longer in place and they wanted a full electric choke.
Whatever reason, that's what you've got now.
I've seen aftermarket chokes run on switched 12v like they say in the instructions, and also seen them work with the original White w/black stripe stator wire from the original choke. At least a few have reported no problems and a perfectly good working choke with the original wire. But since "your results may vary" I would try it and see. If it does not work to your satisfaction you can find another wire for a switched 12v source.
Paul
Rollbar
17
Jan 4, 2020 10:47 AM
gostephen
Dec 17, 2018 10:14 PM
jomoflymo
32
Aug 2, 2014 03:27 PM
bradford237
Jan 14, 2013 08:24 PM
82'Stepside
24
Jan 6, 2009 12:33 AM
