Exaust heat problems
Old Mar 2, 2021 | 05:08 PM
  #31
bewildered 7.3's Avatar
bewildered 7.3
Originally Posted by Dan V
The soot on the firewall, if new, tells us that you have a MASSIVE exhaust leak.
I believe that is new, and it also goes with what Sous and other have been trying to tell me for a couple days.
Old Mar 2, 2021 | 06:00 PM
  #32
bewildered 7.3
exh leak
So, the massive exhaust leak is between the up pipe manifold and the turbo. I was very careful when I installed my turbo, and left the pedestal bolts loose to help align this mating surface. I can't see any gasket was ever in here, it would need to be very hi temp if it were.
Old Mar 2, 2021 | 06:09 PM
  #33
Wes444's Avatar
Wes444
Not just loose pedestal bolts, when you align the turbo to pedestal you want the uppipes nearly completely unbolted from the exhaust manifold. Leave those loose till the turbo is mounted, then crawl under and tighten up the manifolds to uppipes. At least with bellowed uppipes, the original uppipes with the donuts will probably leak doing it that way, granted they should also bolt up and align perfectly without needing to undo them below
Old Mar 2, 2021 | 06:10 PM
  #34
RacinJasonWV's Avatar
RacinJasonWV
There is no gasket at that location. It must not have been properly seated for some reason. Watch the small pin. I have heard of some people having issues with the locating pin on the cheaper pipes. That was not my experience however as both cheap sets I’ve installed fit well.
SSJ will probably be along with his words of wisdom for the best install method. He’s done tons of these.
edit: Wes added his words of wisdom while I was typing.
Old Mar 2, 2021 | 06:31 PM
  #35
bewildered 7.3
good tip, thanks, I'll go pull my inner fender on the passenger side
Old Mar 2, 2021 | 06:33 PM
  #36
Wes444's Avatar
Wes444
Inner fender? I can reach mine from below. Granted I have kid hands not gorilla hands like some blessed guys.
Does it run hot when you aren't running a hotter tune? I wouldn't run a chip without an EGT probe
Old Mar 2, 2021 | 07:02 PM
  #37
Dan V's Avatar
Dan V
my motto.....often wrong, never in doubt.
Old Mar 2, 2021 | 07:37 PM
  #38
bewildered 7.3
yes, but it had the same exhaust leaks before I fixed them
Old Mar 2, 2021 | 07:46 PM
  #39
bewildered 7.3
yeah, my starboard side is above the starter, with a couple inches between the starter and the frame rail, easier to pop the inner fender off.
Old Mar 2, 2021 | 10:32 PM
  #40
lpzd's Avatar
lpzd
[QUOTE=bewildered 7.3;19760865]I do not, I wish I did.
I also wormed a hand back there and I can not move the waste gate rod. Since it is on a vacuum pot??? I think I should be able to push it toward that pot with minimal effort??? I will post a pic, soon as I get it off my phone.
That pot uses pressure, not vacuum the rod will not move towards driver side and should take some serious effort to move towards the passenger side.
Old Mar 2, 2021 | 10:39 PM
  #41
bewildered 7.3
[QUOTE=lpzd;19761513]
Thanks, I feel better about that!
Old Mar 3, 2021 | 02:30 PM
  #42
bewildered 7.3
who knows a good source for these turbo flange clamps? I'm convinced that the old ones are stretched a bit. Even if they are not, it's not that much fun to keep ripping this apart, why not replace them?
Old Mar 3, 2021 | 03:46 PM
  #43
Wes444's Avatar
Wes444
Riff Raff has them. Finally replaced mine after it was mangled from 3rd reinstall. Think the first time did the most "damage" to it tho. They came off way easier after I had lightly coated them with anti seize on previous removals.
Old Mar 4, 2021 | 02:06 AM
  #44
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Another tip for clamp longevity is smack the collector, not the clamp.
Getting the collector to align properly with the baby's butt is a giant PITA for everybody, and often done wrong. Get some pics next time you are in there.
Bad clamp alignment above
Sweet sweet butt clampage
Old Mar 4, 2021 | 11:18 AM
  #45
MountainManRobb's Avatar
MountainManRobb
Do you also have an issue with the down pipe clamp? Hopefully this will be the start of getting your problem well under way to being resolved!
