2019 F250 Engine codes
Old Feb 27, 2021 | 12:14 PM
Eron taylor's Avatar
Eron taylor
Sorry if this post is in the wrong place. If so please redirect me. I have a 2019 F250 with 6.7 powerstroke with a little less then 16k miles. I was just leaving my house and about 500ft down the road my truck went into limp mode. Threw a low fuel pressure code. It’s 46 degrees outside and has been roughly that temperature for a few days. My last Fill up was yesterday and I put hot shot EDT in as I always do. I didn’t really warm it up. I pulled over plugged in my FORScan and got codes P0236(turbo boost sensor circuit range range/performance) and P008A(low pressure fuel system, pressure too low). I cleared the codes and it ran fine the next mile I drove to get where I was going. Truck is stock.
Has this happened to anyone else? What could have caused this? How serious is this? Should I bring it to the dealership or should I wait to see if it happens again?
any help is appreciated. Thanks in advance.
Old Feb 27, 2021 | 03:28 PM
The Bone's Avatar
The Bone
Since it is still under warranty I would defiantly take it in. Usually you can't just clear a code and limp mode goes away. That is odd to me. 46 degrees isnt enough to mess with the fuel.
Old Mar 1, 2021 | 09:32 AM
speakerfritz's Avatar
speakerfritz
the issue is not what the temp was when the condition occured....but rather ...what were the temps proceeding
low pressure could be water in fuel that frozen or wax build up from gelling
frakchered
6.7L Power Stroke Diesel
Sep 13, 2020 07:05 PM
strokin'_tatsch
Dec 5, 2007 06:07 PM
90F250351
Aug 3, 2007 08:44 AM
SD luvr
Computer Chips & Tuners
Jul 26, 2006 05:39 PM
modeltford
1983 - 2012 Ranger & B-Series
20
Nov 15, 2004 02:01 PM
