Oil Pressure?
Old Feb 26, 2021 | 02:10 PM
rdayt's Avatar
rdayt
Oil Pressure?
A couple weeks ago I started my truck up and the oil indicator went to zero.
It was midway with the key on engine off but when I started it it went to zero.
Went to O'Reilly's and got a mechanical gauge and put on it and now I get this,
This is warmed up and idling at 7-800 rpm.
Is it supposed to be this high?
Going down the road it runs about 35-40 lbs.
Everything I've found online is worried about low pressure and says it's supposed to be about 10 lbs per 1000 rpm.
Just looking for feedback.
Thanks
Old Feb 26, 2021 | 03:26 PM
85e150's Avatar
85e150
That's fne. 10lbs per 1000 rpm is the minimum you need to keep the spinning bits riding on a wedge of oil.
What weight oil are you running?
El Padrino
Feb 9, 2014 05:29 PM
stxoil
Jun 5, 2013 02:19 PM
aaronlockhart
Mar 21, 2009 11:14 AM
rmalottwtes30
Mar 6, 2008 06:33 PM
ford784x4
1978 - 1996 Big Bronco
22
Aug 12, 2005 07:26 PM
