IRP or PCM issue???
Old Feb 26, 2021 | 01:21 PM
fluidp's Avatar
fluidp
IRP or PCM issue???
Hi all, This is a new crank no start condition for me. My wood truck is a 94 f250 7.3 psd auto. I put it in the truck 14 years ago... Don't use it that much, but I have always been able to work through the issues..
OK so crank no start. did the usual checks, unplug icp, nothing... tested GPR,, all good. swapped out IDM, not the problem.. So I put a 3000 psi guage on the high pressure circuit,. The pressure buried the gauge while cranking over. Like past 3000 psi....
I also tried cranking while ICP was unplugged and same thing.
So is the IRP stuck closed, or is the PCM not doing its job??
Any ideas before I dive into either the PCM or IRP swap.. I do have a spare PCM I will try hooking up first....
Cheers
Old Feb 26, 2021 | 02:25 PM
fluidp's Avatar
fluidp
OK,, I plugged in my spare PCM and turned it over... The ICP was up and down and then it fired.. Ran for a couple seconds then died. Now the batteries are too low... Also, I forgot to plug the ICP sensor back in. Will let batts charge and plug the sensor in and try again. But looks like the PCM may be acting up....
Question... Is the IRP in "Normally Closed" when ignition is off???
Thanks
Old Feb 26, 2021 | 10:52 PM
fluidp's Avatar
fluidp
My spare PCM worked...
Old Feb 27, 2021 | 09:09 AM
Airstreamer67's Avatar
Airstreamer67
Kudos to you! Hope it's the permanent fix. Thanks for keeping us up to date.
bigbubba87
Nov 25, 2020 07:19 PM
whybnormal
Jun 8, 2015 11:56 AM
j.bagg19
Nov 18, 2014 06:34 PM
orphius
Nov 16, 2013 05:56 PM
khadma
Electrical Systems/Wiring
Oct 2, 2012 07:36 AM
