Weak battery, Code 512
Old Feb 24, 2021 | 07:35 PM
Dan P's Avatar
Dan P
95 F150 XLT SC 4x4 5.8l E4OD
So recently I got a KOEO code of 512....KAM failure...I understand this could be the ECM, but I also read that a weak battery could cause this code if the voltage drops too low.
My battery was a recycled battery the PO put in in, and I know it's needing replacement. During cranking it would drop to around 9 volts so before replacing the ECM, I put in a fresh battery. It cranks at around 11 volts now and the starter spins noticed faster. I figure changing the battery would also clear the codes. I took it for a drive and checked codes again.
512 still shows KOEO. I only started it and drove it once since installing the battery. If 512 is in fact from the weak battery, will the code eventually go away or should it already be gone, leading me back to the possibility of an ECM?
Thanks!
Old Feb 25, 2021 | 06:28 AM
rla2005's Avatar
rla2005
Code 512 is not a KOEO code, it's a stored code in Continuous Memory. It will take 40 or 80 drive cycles to clear by itself. Or clear the codes from Continuous Memory. This is done by initiating the KOEO tests then disconnecting the code reader as the codes are starting to flashout. Removing the battery cable to clear the codes will most likely result in falsely triggering Code 512 again.
Old Feb 25, 2021 | 09:35 AM
Dan P's Avatar
Dan P
Excellent! That's exactly what I needed! Thanks!
GreaseGun Joe
May 30, 2021 08:01 AM
Da_Lariat_Chariot
16
Dec 22, 2017 08:34 AM
buddy-z
1983 - 2012 Ranger & B-Series
Mar 10, 2012 12:42 PM
SuperDutyKing
Modular V10 (6.8l)
May 10, 2011 08:21 PM
KEVINS800
Apr 4, 2005 05:31 AM
