electrical gremlin
Old Feb 25, 2021 | 04:07 PM
  #31
speakerfritz's Avatar
speakerfritz
I see pcm, is that what I should reset?
Old Feb 25, 2021 | 04:09 PM
  #32
speakerfritz
Tried to reset pcm
came back as service procedure not supported
Old Feb 25, 2021 | 04:22 PM
  #33
speakerfritz
O bms or bcm in my service procedures list
Old Feb 25, 2021 | 05:32 PM
  #34
ford390gashog's Avatar
ford390gashog
Well this looks different, are you using the most current version? The PCM is not supported because forscan doesn't have access. No worries there because the BMS is in the body control module BdyCM . You can push a full reset to the body control module but you will need to clear the code first.
Old Feb 25, 2021 | 06:05 PM
  #35
speakerfritz
Cleared the code then did the reset
meesage and light returned
heres some info on the code p0620 and some generator data
dont know what the data means
getting good charge voltage
but the generator data shows faults and some really wired frequencies
thanks for your relay
btw, I downloaded forscan from the forum link, I didn’t see anything about updates but I’ll hunt that down
  #36
speakerfritz
Plus 10 characters
Old Feb 25, 2021 | 06:10 PM
  #37
speakerfritz
Just checked and I have the latest version v2.3.38
Old Feb 25, 2021 | 06:23 PM
  #38
speakerfritz
I wish I had a harness to swap generator roles
there are faults in the prinary
if I swap the role and the faults move to secondary then that would point to prinary alt being bad
if the fault does not move then that would suggest wiring or pcm
does that make sense
Old Feb 25, 2021 | 06:29 PM
  #39
dirthawg's Avatar
dirthawg
My bet is you have a faulty generator or pcm but leaning towards the generator.
Old Feb 25, 2021 | 06:34 PM
  #40
speakerfritz
I have connectors coming in on saturday
hopefully I can make a pair of pcm extension cables
swap the roles and see if the problem moves
if it is an alternator will have to decide if I want to out of pocket this
if I take it in for service...it’s going to cost me vacation days, rentals, and 90 minutes of drive time each wAy
alternator could fry on the way
maybe if I can swap the roles I’ll drive it with just the good alternator connected
Lots to think about
thanks and will keep all posted
Old Feb 25, 2021 | 06:45 PM
  #41
helifixer's Avatar
helifixer
Lots to think about
the code would still stay the same if the problem is in the control and not the alternator.
the only way to check that is to switch alternators (if they are the same)
Old Feb 25, 2021 | 06:55 PM
  #42
speakerfritz
correct
all I need to do is swap pcm connection
dont need to physically move the alternators
will be making the cables sat that will let me test this
Old Feb 26, 2021 | 02:05 PM
  #43
speakerfritz
Update
i disconnected the pcm connector from the primary and get 13.8 ad charge voltage
this is a correct number for the alternator in dumb mode.
Saturday I’ll have the parts to make cables to swap rolls to learn more.
Old Feb 27, 2021 | 11:27 AM
  #44
speakerfritz
Received the parts for the extension cables
cables will be used to swap alternator roles
prinary will be secondary
se o dart will be primary
question will be did the faults follow the alternator suggesting bad alternator
or
did the faults remain suggesting pcm circuit problem
Old Feb 27, 2021 | 11:33 AM
  #45
dirthawg's Avatar
dirthawg
That's enough teasing get them connected!
