Blower Motor Upgrade?
Old Feb 22, 2021 | 07:21 PM
Rustyol79's Avatar
Rustyol79
Any suggestions on a blower motor upgrade for a 1979 F-150 with standard heat?
Old Feb 22, 2021 | 08:29 PM
meangreen92's Avatar
meangreen92
The only upgrade I know of is the Mustang ('71-'73 I believe) heater box, which equals the heavy duty heater in these trucks. But I don't know if it has a stronger blower motor.
You can make sure that your heater box is clean of obstructions, and that the motor turns the right way - I've seen replacement motors bolt right in, but turn the wrong way...
Old Feb 22, 2021 | 10:11 PM
John89's Avatar
John89
Someone posted a thread about this a couple of months ago.
I don't remember the details off the top of my head.
Do a search and see what you come up with.
Old Feb 23, 2021 | 07:38 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I am not sure it a 66-77 Bronco has the same blower motor as a Ford truck, I would think so? The common mod for an early Bronco blower motor is to swap in a ....chebby one. I know blasphemy, but whatever keeps you warmer. I think you have to trim the box (on a Bronco) for the bigger squirrel cage.
Napa blower motor # 655-1039 = Advance Auto p/n: 35587 for $20
Napa squirrel cage # 655-1406 = Advance Auto p/n: 35602 for $14
Advance auto, and they had the heater motor, but the cage is a 35601-not the 35602
Autozone part numbers: PM102 blower motor 35602 blower cage
https://classicbroncos.com/forums/sh...+motor+upgrade
FTE threads.
https://www.ford-trucks.com/forums/8...+motor+upgrade
https://www.ford-trucks.com/forums/1...+motor+upgrade
https://www.ford-trucks.com/forums/9...+motor+upgrade
Might as well put a new heater core in since you have the box out.
Old Feb 23, 2021 | 07:53 AM
77&79F250's Avatar
77&79F250
Just in case you do this I have what I hope is some help.
Removal and Installation of Heater Core Assembly
First, take a lot of pics before you remove anything. And use zip lock bags to store screws and nut as you remove screws and nuts, this will help you keep things organize during removal and installation of hardware.
Read instruction, before purchasing parts needed.
Parts need: 1 heater core, 2 gallons of antifreeze, 1 RTV silicone rubber or 1 weather strip adhesive, 1 heater fan motor (recommended), anti seize compound for radiator hoses.
  1. Loosen peacock onradiatorto drain the radiator fluid from the radiator. Use a container to store the radiator fluid (antifreeze). Tighten peacock when fluid has drained.
  2. Remove glove box door, 2 hinges, 2 screws per hinge, and the cable which attaches to the glove box door.
  3. Remove the black glove box behind the glove box door. (use a very short screw driver). Tape up the SHARP L/H and R/H edges of the glove box opening.
  4. Move glove box to the left side to access the lower vent door screws on passenger side of truck and remove screws to lower vent door. Remove the lower vent door, use a short and medium phillips screw driver.
  5. Now remove the black glove box, from the bottom, where the lower vent door was located.
  6. Locate the heater cables from the heater core assembly (big black unit, mounted under the dash), it is easier to find if you move the selectors for the heat or vent and floor selections on the dash above the radio. At the end of cable, locate the one screw mounted to the heater core assembly, and with a short phillips screw driver, remove the screws at the end of the cables, remove heater cables and tie up and out of the way.
  7. Locate the floor heater vent, this is locate in the front center lower portion, inside the truck, and is mounted to the heater core assembly, below the ashtray. Remove the two clips with a set of pliers, be careful not to break or chip the heater core assembly when removing these clips.
  8. On the inside of truck, on the heater core assembly, on the right side (passenger side), under the dash, locate and disconnect the wiring harness that mounts to the big black unit, tie wiring harness up and out of the way.
  9. In the engine compartment, locate the fan motor, remove the wiring harness and the screw for the ground wire, which attaches to the fan motor.
  10. Loosen and slide away the the two heater hose clamps mounted to the heater core, at right (passenger side) rear firewall, of the the engine compartment, in the engine compartment.
  11. Remove heater hoses from the heater core at the rear of the engine compartment. Sometimes it easier to slice the rubber heater hose mounted to the heater core with a utility blade, use a regular screw drive to pry the heater hose away from the heater core. Use a container to catch any radiator fluid (antifreeze) leaking from heater hoses.
  12. Loosen the three nuts under the engine compartment (they look like 3/8" bolt sticking out of the firewall with a nut mounted to it). One is located on the rear portion of the fire wall and is located behind the right valve cover on the fire wall, most of the time there is a ground wire attached to it, remove the nut to remove the ground wire, and remove the nut behind the ground wire. The other two is located near the fan motor on the fire wall. Remove the three nuts.
  13. The heater core assembly is ready for removal.
  14. From the inside of truck. Wiggle and remove the heater core assembly. Patience is a virtue. Have some rags nearby to soak up any radiator fluid which leaks in the vehicle.
  15. After heater assembly is removed, find a clean area to place the heater core assembly. Tailgate....
  16. Locate the heater core and remove the screws and bracket.
  17. Remove the heater core from the heater core assembly.
  18. Save the old heater core, you will need the rubber and foam attached to it.
  19. When purchasing your new heater core, take it with you to the automotive store, to match the old heater core with the new heater core.
  20. Place the rubbers and foams off the old heater core on to the new heater core. Use a weather strip adhesive or RTV silicone to attached it.
  21. Before placing the new heater core onto heater core assembly. Remove fan motor screws and remove fan motor. Rinse out heater core assembly with water. Use a cotton rag and bucket of water with Pinesol, to wash the inside and outside of heater control assembly.
    Wash and rinse to accomplish necessary results. Dry with a cloth.
  22. Optional and highly recommended. Take into consideration replacing old fan motor with a new fan motor at this time, you might not want to remove fan motor a year or so from now. If your new motor does not have a plug, make sure to wire it properly. Color matching does NOT always make it turn the correct direction. Test before hard install. A new motor does NOT come with a squirrel cage. Use your old one, held on motor shaft with an Allen screw. Long type Allen wrench, down thru the fan blade gap work fine.
  23. Installation of heater core and heater core assembly.Follow instructions from step 18 backward to step 7. (if rubber foam needs to be replaced on heater core, use the rubber insulating foam for pipes)
  24. On step 6, make sure heater cables are adjusted correctly. Then, follow step 5 to step 2.
  25. Fill radiator, as recommended on label on antifreeze bottle, with new antifreeze and water.
  26. Check for leaks.
Note:
  • Check for leaks on radiator, fix if necessary.
  1. Use anti seize compound for radiator hoses on installation of the hoses, as it will ease have to remove hoses later, if needed.
  2. Check the condition of heater hose, replace if necessary.
  3. Replace thermostat if necessary.
  4. Replace radiator hose(s) if necessary.
Old Feb 23, 2021 | 09:35 AM
Rustyol79's Avatar
Rustyol79
I put the high output heater out of 79 Bronco in it. The blower motor was squealing during the cold weather we had last week and I was wondering if there was a better alternative for a replacement blower motor. Thanks for your replies.
Mark8man
Feb 14, 2020 11:02 AM
AK FORD GUY
Apr 19, 2014 12:23 PM
farmallcrew
Feb 13, 2008 02:14 PM
spartan117_mc
Oct 16, 2006 01:56 PM
masterbeavis
Oct 28, 2002 10:53 PM
