Random ABS Light - RESOLVED - stripped bolt
Old Feb 22, 2021 | 11:26 AM
F250_'s Avatar
F250_
I share this in the event that it may help someone else.
Been having a random ABS light showing up in the past few months. Generally, shutting down the engine and restarting would resolve it, but not always. I replaced the rear VSS and it made no difference.
Finally got under the truck yesterday and tracked it down to a stripped bolt on the DS front wheel sensor. It was holding firm enough to not allow the sensor to back out, but was also loose enough to where a road bump could cause it to move enough to set the light.
The saga is not yet over, though, because I snapped off my tap while trying to prep for a helicoil insert (working from under the truck with the wheel in place). Will now have to make some room in the garage to get the truck up and remove the wheel so I can work "in the open" to drill and tap a new hole for the mounting bolt.
Old Feb 22, 2021 | 08:14 PM
Ford Firefighter's Avatar
Ford Firefighter
Been having the same exact problem! I’ll give that a check, thanks!
Do you think it is an OEM problem or did someone screw something up?
Old Feb 23, 2021 | 11:44 AM
F250_'s Avatar
F250_
I'm the one who screwed it up. When I replaced my rotors, I evidently tightened down a bit too hard on the bolt.
ABSBoltSuicide
Jun 28, 2019 03:48 AM
bronco2454
1997 - 2003 F150
Mar 1, 2011 04:18 PM
peter p
1997 - 2003 F150
Jan 25, 2010 10:26 AM
Jonesy44
1997 - 2003 F150
Sep 18, 2004 12:06 AM
pezley69
1978 - 1996 Big Bronco
Jan 21, 2004 09:56 AM
