99 explorer bucks
Old Oct 26, 2003 | 09:39 PM
flash78233's Avatar
flash78233
Unhappy 99 explorer bucks
Hello all,
My 1999 explorer just developed an issue. While crusing the truck stumbles at approx 1500 RPMS. Acts like it is losing power. While going down the highway and on a slight incline the stumble is most noticable, it also backfires somewhat. Does any one have any ideas on what may be wrong.
5.0 liter enging
52k miles
AWD
Old Oct 27, 2003 | 01:21 AM
r3830's Avatar
r3830
Dear Flash78233,
Just a few thoughts that may assist......compliments of a Haynes manual.
1. Spark Plugs and Leads.....gaps can grow over time which can upset timing.
2. The manual refers to an EGR system not functioning properly
3. Vacuum leak at manifold
4. Clogged air filter.
I have the V6 pushrod model which is equipped with a MAF Sensor. The difference it made to the overall performance when the MAF was removed and cleaned was incredible - including at low idle. Looking at the diagram of the 5.0L motor, yours is equipped with the same device. (down near the air filter on the main air intake.) Removal isn't difficult - nor is cleaning. Spray it out with a circuit cleaning spray available at most electronic stores. (used to be FREON prior to the hole in the ozone layer.)
Hope these things may help.
Paul.
Old Oct 27, 2003 | 05:44 PM
flash78233's Avatar
flash78233
Thanks
Thanks for the ideas, I brought it in to the dealer to get it looked at, it is still under the extended warranty. Still no word on what is wrong, they havent looked at it yet. I also had them replace the control arm bushing boot, that was torn. Question I have is a front end alignment required after this is done? They recommend this at a cost of $100.00 +. It is not required and therefore not covered under the warranty. Again thanks and will post the fix when I get the truck back.
Todd
Old Oct 27, 2003 | 06:00 PM
r3830's Avatar
r3830
Todd,
The alignment sounds like a good idea - but appears to be terribly expensive at $100. I had new tyres fitted recently, along with an alignment. The alignment itself cost $42AU. (around $15US)
While I don'tknow the rates over there, it may pay to shop around.
Take care - and I look forward to hearing your POSITIVE solution that the dealer will I HOPE provide!
Paul.
Old Oct 28, 2003 | 11:31 AM
flash78233's Avatar
flash78233
Just got off the phone with the service rep. The check engine light is due to the plug wires, (enging code P0304, #4 misfire). They want $400.00 plus to change the wires or $200.00 plus for a set of wires, seems extremly high for plug wires. I am going to change them myself. I am having them do a tune up for $250.00 while they have it, which includes plugs, fuel filter, air filter, fuel injection cleaning, intake cleaning, and reset of the computer. Who knows maybe the tune up will fix the check engine light. Will post when I get the truck back, hopefully good news. I know what I will be doing this weekend, (plug wires).
Flash
Old Oct 30, 2003 | 09:18 AM
flash78233's Avatar
flash78233
Got the truck back and it is running fine. Still wanted to replace the wires. What a fun job, took about 2 hrs. Still think it was worth the $300.00 savings. The #4 wire was the worst, I think the engineer was playing a joke on the owners. The dealer told me the #4 plug was bad from tracking on the #4 wire. I never heard of such a thing. I think they were just trying to get a few extra bucks, when I got the #4 wire off I could not find any arcing. Anyway all is fine now and it is running good. Hopefully this will last awhile. Just have to wait and see.
Thanks all
Todd
Old Oct 30, 2003 | 05:03 PM
r3830's Avatar
r3830
I,m having REAL DIFFICULTIES understanding the costs of things over there. I had to replace the leads on my V6 and was unable to buy aftermarket. The cost of these through our Ford rep was $75AU. Plugs were replaced with Iridiums, at about $22 each. Nevertheless, it's good news to hear that all is well for you.
Paul.
WillFargo
17
Aug 13, 2012 09:40 AM
hartski
2004 - 2008 F150
May 31, 2012 01:46 PM
67nukeford
Aug 19, 2011 09:17 AM
99FORD EXPY.
Aug 9, 2011 07:47 PM
1bad04
Dec 22, 2010 09:33 PM
