acceleration stumble when cold
Old Aug 7, 2011 | 08:22 PM
99FORD EXPY.'s Avatar
99FORD EXPY.
2006 V6 explorer stumbles only when cold other then that it runs great
any ideas its been doing it for a month i tried fuel treatment didnt help ,water remover no help, no codes either
thanks
Old Aug 8, 2011 | 06:38 AM
shorod's Avatar
shorod
Is it a single stumble on acceleration or a more of a series of sputters? What is the engine speed at idle when cold? Do you have access to a scan tool with datastream mode? When's the last time a tune up was performed (spark plugs, fuel filter, air filter)? I suspect your 2006 has Coil on Plug (CoP) ignition. Have you checked fuel pressure? You might try cleaning the MAF sensor as well. If you don't have access to the sensor datastream, there will be some guessing as to where to start.
-Rod
Old Aug 8, 2011 | 03:33 PM
99FORD EXPY.
tune up was done 2 months ago no problems then, no scan tool
its a series of 4 stumbles only when cold i will try to clean the MAF sensor tonight, i have not checked the fuel pressure , i dont even now were to start with that
Old Aug 8, 2011 | 03:42 PM
aquanaut20's Avatar
aquanaut20
You need to borrow a scan tool
It may be the coolant temp (NOT dash gauge) is sending a hot engine signal to the CPM, causing lean stumble when cold... Philip
Old Aug 8, 2011 | 07:18 PM
99FORD EXPY.
what brand of scan tool
shorod said it should have datastreaming
Old Aug 8, 2011 | 09:56 PM
aquanaut20's Avatar
aquanaut20
Edit: duplicate entry
aquanaut20's Avatar
aquanaut20
A scan tool (scanner) includes live data by default, if not it is a code reader...
I have made several recommendations in the past 2 months, maybe you could try a search... Philip
Old Aug 8, 2011 | 10:09 PM
99FORD EXPY.
thanks i will
Old Aug 9, 2011 | 12:06 PM
aquanaut20's Avatar
aquanaut20
Old Aug 9, 2011 | 07:47 PM
99FORD EXPY.
checking on it right now thanks
mediaman67
Aerostar
Oct 11, 2014 01:42 AM
oneowner83
Feb 4, 2014 03:13 PM
delachshack
Oct 28, 2013 06:58 AM
BSHORT
1983 - 2012 Ranger & B-Series
Nov 24, 2007 09:20 PM
ACHANDLER
Dec 29, 2006 08:55 AM
