Diesel "stuff"
Old Feb 21, 2021 | 12:14 PM
Joe T's Avatar
Joe T
I run standyne in every tank. It got down to like 14 here last week. I dont use my truck much so forgot when i filled it last but it probably wasn’t a special winter blend. It rarely freezes here. Truck ran fine.
If you drive a lot and dont want the expense of the additive then at least put it in while towing. That way when you go south/north you are protected. It will run a little better too and protect you against water in fuel at random stations as you travel.
Old Feb 21, 2021 | 12:42 PM
RA101725's Avatar
RA101725
Banned
Originally Posted by speakerfritz
The lower the number the greater the lube value. I think 520 is the target number. untreated #1 diesel does not meet ASTM or EMA min standard.
Nor does #2 ULSD according to the chart, however places that sell #1 diesel and "premium #2" it will often be pre-mixed right out of the pump with lubricity additives. This will vary from region to region and distributor to distributor. Adding your own lubricity additive is always a wise idea.
Old Feb 21, 2021 | 12:48 PM
RA101725's Avatar
RA101725
Banned
It adds anywhere from $3-4 on a $60-70 fill up for a heavy dose of PS white or grey bottle. You'd have to be going through a damn lot of fuel to make that add up to any amount of money you'd miss. Anybody pinching pennies and bean counting that hard would have realized how much cheaper running a gasser would have been and bought that instead lol.
Old Feb 21, 2021 | 12:50 PM
HRTKD's Avatar
HRTKD
Oh, you didn't just go there, did you?
Old Feb 21, 2021 | 05:24 PM
speakerfritz's Avatar
speakerfritz
I want to believe this just as much as I believe every service station can do a print out from their super duper fuel quality monitoring system of water content report .
anyone have any charts that show the major players and the additives they add? would love to see one.
Old Feb 21, 2021 | 06:32 PM
KJCC's Avatar
KJCC
Agreed! Anyone???? Would love to see.
Old Feb 21, 2021 | 06:39 PM
AceRed's Avatar
AceRed
Sounds like keeping a few bottles of anti gel for temps exceeding -20, or going south and getting caught in below freezing temps like they did last week is recommended. Having a set of fuel filters on hand a good choice. I will have to do some more research on the lubrication additives and what's real and what is perceived. Good discussion and appreciative.
Old Feb 21, 2021 | 06:52 PM
AceRed's Avatar
AceRed
What about gauges? I see a lot of Diesels with a set of gauges monitoring "something" on their dash. Anything worthwhile here?
Old Feb 21, 2021 | 06:58 PM
senix's Avatar
senix
I use an idash for monitoring
Old Feb 21, 2021 | 07:00 PM
AceRed's Avatar
AceRed
What are we monitoring that the truck doesn't show already?
Thanks
Old Feb 21, 2021 | 07:03 PM
C12H24's Avatar
C12H24
Not really. What you're seeing is a lot of OCD. The fuel gauge is the most vital thing to monitor. Keep an eye on your DEF if you're towing heavy over distance. So, the two things that are consumed are worth monitoring. You can monitor all of the sensors in the truck with the right software and hardware. Very easy to do. But you easily get into information overload and you find you're looking only at the speedometer and the fuel gauge, and, again, the DEF from time to time. If you have a problem, the truck will let you know.
Old Feb 21, 2021 | 07:04 PM
senix's Avatar
senix
In my pic above, I monitor EGT 11 and EGT 14, useful in turbo temps and dpf temps/ EGT 11 I won't shut the truck off until EGT hits below 400F
I also monitor Actual coolant and oil temps since I tow pretty heavy.
Dpf regen status and distance between.
And Trans temps.
Dummy gauges give you some of the info but no actual numbers.
DPF regen status so you don't shut a hot truck down or in the middle of a regen.
Old Feb 21, 2021 | 07:42 PM
  #28
HRTKD's Avatar
HRTKD
With the FORScan Lite app on a phone you can monitor just about anything that a standalone gauge can. I used FORScan Lite for a couple of trips. After that, I really didn't care all that much. The 6.7L just goes and goes and I don't have to worry about it.
  #29
RA101725's Avatar
RA101725
Banned
This topic might be approaching unhealthy levels of exposure for you. (Like sitting in the sun too long)
Old Feb 21, 2021 | 09:12 PM
  #30
CJONE's Avatar
CJONE
I always run premium diesel and buy from the same supplier for the last 30 years. I have never had a truck jell and the fleet of 40 or so trucks and 30 loaders / dozers ect never did either. With no additives except some power service once in awhile. I have never had a water issue either. Once you get some miles on it switch to a 5/40 full synthetic for starting when it is in the 20 below range OR just plug it in if sitting for more than 8 hours or so. GET THE SUPPLEMENTAL HEAT. These things are horrible to warm up! I guess that is what happens when you have to cool so much hp when it is hot out but dang these things are cold blooded! Cj
