U joint strap kit 4x4
Old Feb 21, 2021 | 08:31 AM
Ridedan2's Avatar
Ridedan2
Looking for some info on the correct u joint strap kit for my E99 (likely same as other years) for the 4x4 driveshaft going into the front differential. I have the u joint however the bolts holding the straps on are not cooperating in the removal process so I would like to get new ones before I begin as most likely these bolts will need replacement. I am looking on rock auto, however there is 3 options and I’m not sure which kit I need. Any help is greatly appreciated.
https://www.rockauto.com/en/catalog/...250+super+duty
Old Feb 21, 2021 | 09:00 AM
Back2Gas?'s Avatar
Back2Gas?
My factory bolts wanted to round off the hex on the outside. Had new ones installed that are socket head cap style, so that issue went away...I would recommend that style.
Old Feb 21, 2021 | 09:03 AM
Ridedan2's Avatar
Ridedan2
Any info on bolt size, thread, length? I don’t necessarily need a strap kit, Just correct bolt size would do the trick. My bolts are rounding as well, Thanks.
Old Feb 21, 2021 | 09:06 AM
FordTruckNoob's Avatar
FordTruckNoob
This should be the right one from Torque King.
If you do decide to get bolts only, be sure to get Grade 8 or better. They are also fine pitch 5/16" bolts.
Old Feb 21, 2021 | 09:25 AM
Ridedan2's Avatar
Ridedan2
perfect, thanks man!
Old Feb 21, 2021 | 10:54 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Originally Posted by Ridedan2
I don’t necessarily need a strap kit.
Why not?
Dana, Spicer, and Ford "universally" recommend a new strap kit whenever universal joints are replaced.
Sources for reference:
Ford Workshop Manual, Driveshaft-Front, Removal and Installation, 205-01-4
  • Remove and discard the fasteners
  • Remove and discard the bolts
  • Remove and discard the U-Joint retainers (aka straps)
  • Install new bolts and retainers
Ford Workshop Manual, Front Drive Axle, Drive Pinion Seal, Disconnecting the Front Driveshaft, 205-03-5-8
  • Remove and discard the four bolts and two retainers (aka straps)
  • Install two new retainers and four new bolts.
Spicer U Joint Retainer Kit Part Numbers: (appropriate for 1350 Series and 1410 Series U joints)
  • Bearing Strap Part Number: 3-70-28X
  • Bolt Part Number: 231142
  • Bolt Thead Size - Pitch: .312-24 (.3125 = 5/16)
  • Bolt Torque Spec: 30-35 ft lbs. / 41 - 47 nm
Note: The Ford Workshop Manual cites a lower torque spec of 26 ft lbs / 35 nm for the U-Joint retainers (straps). This could either be a clerical error (there are several throughout the service manual, including the Table of Contents which misidentified the front driveshaft section), or, it could be because "two types of universal joints are used: a Dana design and a Ford Design" (205-01-12).
Torque value specs for the four flange bolts into the transfer case output flange are significantly higher, at 76 ft lbs / 102 nm.
Old Feb 21, 2021 | 11:09 AM
Ridedan2's Avatar
Ridedan2
Wow thanks for that wealth of info. I went ahead and ordered the bolts and retainers. Now I know the torque specs as well. Thank you.
Old Feb 22, 2021 | 09:15 AM
Back2Gas?'s Avatar
Back2Gas?
IIRC, my strap kit with bolts was about $10, a no brainer. lol
pb34
2004 - 2008 F150
30
Sep 3, 2009 09:21 PM
displacement4me
Feb 9, 2009 11:51 PM
jchamb11
Nov 14, 2008 07:44 AM
93Mule
1978 - 1996 Big Bronco
Jun 28, 2008 07:22 AM
blue 2004 FX4
2004 - 2008 F150
37
May 4, 2004 09:36 AM
