Door jam sticker
Old Feb 20, 2021 | 11:14 PM
Leo Shurks's Avatar
Leo Shurks
Door jam sticker
I've had my truck for a couple years now and I had recently found an old registration for it and I said it was a 1978 but the current one says it a 1979 dont know what's going on there, I've been trying to look up information about the truck and the sites I found have a bunch of letters on the door jam stickers where as mine is not filled out, I've decoded the vin and it said its cataloged year is 1978. Just wondering if anyone else has had a door jam sticker like this with no information on it
Old Feb 21, 2021 | 12:13 AM
mwoj's Avatar
mwoj
I don’t think I’ve seen one filled out. All the real info is on the metal door tag.
Old Feb 21, 2021 | 12:16 AM
cwegga's Avatar
cwegga
I think mine is like that. The information that isn't filled out is on the my door vin tag instead.
Leo Shurks's Avatar
Leo Shurks
well I guess I'm outta luck then cause the tag on the door is not there
Old Feb 21, 2021 | 12:23 AM
meangreen92's Avatar
meangreen92
You've got four places on the truck where the VIN is displayed that I know of: 1, the metal Warranty Tag on the driver's door. 2,that data sticker on the driver's door jamb of the cab. (I forget what it's called, and Number Dummy probably isn't going to correct me...) And 3 and 4, two spots on the passenger side frame rail, one under the alternator, and the other under the passenger side floorboard - you'll need a mirror, or the camera feature on your 'smart' phone, to see that one...
You should 'reconcile' these VINs to make sure that they all match.
Old Feb 21, 2021 | 12:48 AM
Leo Shurks's Avatar
Leo Shurks
the metal warranty tag isn't on the door the holes where it should be riveted are there the trucks got the 79 front end on it, ill look tomorrow at the places you've said
Old Feb 21, 2021 | 12:55 AM
meangreen92
You can find pictures of the frame VIN locations here on FTE, or via a search engine.
Pretty sick-looking rig!
Old Feb 21, 2021 | 04:28 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
That is a Safety Certification Label (aka the white sticker) and it is showing a build date of 7/78 so July of 1978 was its birthday. I believe that is considered late year by Ford (?) or the DMV, so that might be why it says 1979 on the title. I would be frame vi# locating and paper title # checking.
All that matters is the paper title Vi# matches the 11 digit VEH IDENT NO on that white sticker. And they both match the truck frame stamp. Yes you should have a Warranty Plate riveted to the dvrs side door edge and it would have the vi# also. And the info to decode. You can get replacement plates and labels from Marti Auto. https://www.martiauto.com/
And correct there are 2 places the vi# is stamped on the frame. Just like where mean green said. But since your is 4wd is will not be in line with the alt and more with the exhaust manifold on the passenger side. See the red box? And yes most of the time the white sticker does not have the info and it is on the Warranty plate.
Passenger side frame rail, see the exhaust manifold?
Under the cab, if you have a bad floor great time to locate the vi#, because you have about 1" clearance from cab floor to frame rail top. See the arrow pointing to the white chalk mark? Just aft of the 2 cross member bolt nuts.
File Type: pdf
SynDave
Sep 6, 2018 08:17 AM
Vadis
British Columbia
May 7, 2014 12:04 AM
Ford240
13
Feb 23, 2014 10:33 PM
ayden2004
Jan 26, 2010 09:22 AM
hoovy
21
Mar 4, 2004 09:34 PM
